flashing cel possible solution?
Old Feb 28, 2010 | 12:57 PM
nx04's Avatar
zoom-zoom
Smile flashing cel possible solution?
i was having flashing cel's and solid cel's for about 2 weeks ,, havent had much time to check it ,
anyways i beat the **** out of the car redline every gear all the time , oil change every 3000kms add a quart or so every 2nd fill up , i got about 75000 kms original motor (04 oem), flooded only twice by past owner did maintenance coils and everything not too long ago car is immaculately maintained
only mod to date is aem cai , mazda has notified me that the problem was a bad starter and was causing carbon block in the rear rotor , i should be getting the car back monday , they said everything is fine ,, i hope
so if people are having loss of power and random misfires
according to mazda it might be a bad starter and for the record , never got the upgraded starter , but as stated by searches on the forum the new starter may or may not work for some people ,
just thought id throw this update out there for others
Old Feb 28, 2010 | 01:02 PM
Jon316G's Avatar
Grasshopper
Did you get the code pulled?
Chances are it was a misfire and you'll focus on the ignition (spark plugs, wires, and/or coils).
I usually change the plugs first.
Old Feb 28, 2010 | 01:08 PM
Easy_E1's Avatar
Haven't heard that one before. Starter causing carbon build up. OK.
As jon316g said, it's more likely an ignition issue.
Old Feb 28, 2010 | 02:04 PM
nx04's Avatar
zoom-zoom
well i switched all of the plugs and wires and thats all ok , mazda covered it under my extended warranty so new starter and they cleaned the carbon out i get it back monday so i cant wait to see if everything is actually 100% fine
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
