Engine Replacement
Old Feb 22, 2010 | 03:39 PM
Groo's Avatar
Engine Replacement
I'm getting my 2004 engine replaced (under warranty, thankfully) - what's my new engine going to look like? MNOA just said it was a remanufactured engine that is "up to the latest specifications" - but I'm guessing its going to be a pre-09 design? Does anyone know the details?
Old Feb 22, 2010 | 03:51 PM
alnielsen's Avatar
It will be an engine, just like the one you have presently. It will have been rebuilt at Mazda's reman facility in Virgina and they do a good job. One of their employees used to post here.
Old Feb 22, 2010 | 04:26 PM
Easy_E1's Avatar
It will be the same 2004/2005 model engine you currently have. Just remanufactured as Al said.
Old Feb 22, 2010 | 04:39 PM
james08's Avatar
how many miles did u have on your rx8 when the engine went... i need an engine replacement on my 2004 rx8 and i only had 66,000 miles on it but i only owned it for a year so the owner before me didnt take good care of the car... its actually getting fixed this week so i should have my car back soon
Old Feb 22, 2010 | 04:43 PM
james08's Avatar
also what does mazda mean by re manufactured its it going to be new engine with new parts or and old engine with old parts that are still working properly??
Old Feb 22, 2010 | 04:48 PM
Groo's Avatar
Mine had 33,000 miles on it. Regular oil changes, sometimes as often as every 2000 miles. I wouldn't assume that your car was abused just because the engine went.
Old Feb 22, 2010 | 04:50 PM
Groo's Avatar
I guess I'm trying to figure out of the "flaws" of the original engine will be be fixed in this new engine, and if so, what specifically about the reman will be different..
jasonrxeight's Avatar
think of it as a rebuilt engine
usually rotaries fail due to apex seals, so shot engines get sent back, replace apex seals and test for compression if they are good, then they are ready to put into the car.
Old Feb 22, 2010 | 04:51 PM
the flaws of the original engine is the flaws of pretty much all S1 engines which is lack of lubrication
Old Feb 22, 2010 | 05:21 PM
Groo's Avatar
Exactly. So just throwing new seals on and sending it back doesn't give me much confidence in the replacement engine. Plus, if it were really that simple I would expect replaced engines would have a hefty core charge from mazda, which to my knowledge they don't?? So I'm guessing & hoping there is more to their "re-manufacturing" process than just swapping out apex seals.
Old Feb 22, 2010 | 08:17 PM
ken-x8's Avatar
They're rebuilt, not overhauled. Everything should be within new specs.
Ken
Old Nov 29, 2024 | 02:13 AM
jaedra's Avatar
Mine was 180,000+
Old Apr 1, 2025 | 12:14 PM
cranf0rd's Avatar
Mixing 4-Port and 6-Port Housings in RX-8 Engine Rebuild – Will It Work?
Hey everyone,
I’m in the middle of rebuilding a 6-port Renesis from an RX-8 and ran into a snag. One of the rotor housings and the rotor itself are no good, so I’m looking for replacements. I’ve got access to a 4-port RX-8 engine and was thinking about pulling the housing from that to use in my 6-port build.
My main question is:
Can I use a 4-port housing on a 6-port RX-8 engine and still have a reliable build? Will it mess with performance or reliability in a noticeable way?
Old May 1, 2025 | 05:22 PM
cranf0rd's Avatar
"Can I Do a Compression Test on My 13B Before Reinstalling It?
Good afternoon everyone, quick question—I just finished rebuilding my 13B and I’ve got a rotary compression tester on hand. I’m wondering if it’s possible to test compression before putting the engine back in the car. I don’t have the starter hooked up yet—any tips or suggestions? Thanks in advance!
Old May 1, 2025 | 08:32 PM
Loki's Avatar
Theoretically yes if you hook up a starter somehow or find another way to turn the crank at speed but it won't mean much until the engine wears in. Also definitely don't turn a dry engine without oil pressure.
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
dbarber
Jul 25, 2015 01:34 PM
