My First RX-8 restore!
Old Feb 21, 2010 | 11:00 AM
Brady's Avatar
So I recently purchased this gem from a local auto salvage. It was insanely cheap so I couldn't pass it up. Only 51600 miles. It dosent run yet, but I think it is just something that needs to be reset, because it will try to start, just wont catch.
I am having trouble finding a Bumper Cover and an ALUMINUM hood (was sent a fiber glass one from a vendor), as well as headlights, but those things are my next steps.
I put the wing on last night, that I pulled of a RX8 that was burned, and slapped it on. I also plan on getting new wheels for it, but haven't decided which.
What would you guys suggest for my ride? I'd like to keep cost low, but of course I want a nice ride.
And I have the air intake, I just took it out to clean it.
Old Feb 21, 2010 | 12:54 PM
Bigbacon's Avatar
2006 WB AT
it has no air filter box or air intake stuff.....
Old Feb 21, 2010 | 01:27 PM
Spoolin8's Avatar
well if you have not done a compression test on it you might want to do that and before you get anything cosmetic, a new engine might be the first thing...
Old Feb 21, 2010 | 01:53 PM
Brady's Avatar
I do have the air box and stuff, I just took it out to clean it.
Old Feb 21, 2010 | 08:46 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
What was wrong with it?
Old Feb 22, 2010 | 04:20 AM
he said he got hood and head light, so I assume it was totaled from front collision
Hmm ... I would say have someone check the frame and make sure its good before you dump any money into it.
Old Feb 22, 2010 | 08:55 AM
fyrstormer's Avatar
2009 RX-8 Touring
<facepalm> I seriously almost asked why there was no engine in it.
Old Feb 22, 2010 | 09:10 AM
BigMikeATL's Avatar
If you're lucky, you might just need a new battery, plugs, coils, and wires.
Old Feb 23, 2010 | 11:36 AM
CTrx8's Avatar
space for rent
what color is it? in the 2nd pic it looks BB but the last it looks like it could be NG.
Old Feb 23, 2010 | 01:24 PM
8 Maniac's Avatar
Senior Member
More info on what the engine does when you try to start it might help with more ideas as to what could be wrong. Typically you need to do more than just reset something if the engine isn't starting.
Old Feb 23, 2010 | 03:30 PM
rodjonathan's Avatar
silent assasin
maybe its flooded :S
Old Feb 23, 2010 | 04:27 PM
Nubo's Avatar
Lubricious
The black windshield-washer reservoir marks that as an early 2004. Not to be too negative (mine's an early 2004), but those had the most engine problems. I think you'd do well by beginning with a compression test, before you throw too much money at it. But if you want to try some simple stuff I'd begin with new plugs/wires/coils. If you can't get it started, a push-start might help get it running. Read up on the decarbon procedure in the DIY section. If you get it runnable, make sure it has all the flash upgrades and recalls from Mazda. Also look up the TSBs at finishlineperformance.com, particularly the one titled "engine cranks, no start".
Old Feb 23, 2010 | 11:25 PM
kersh4w's Avatar
Hit & Run Magnet
i'd get it running before you buy new rims.
here's what i'd suggest before you spend any money on it:
push it to 7-8 miles an hour, and let the clutch out in 2nd gear.
if it needs any of the small things, it will still start. if the engine is blown, it will not start. if its flooded, it will still start like this.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Tsurugi
Sep 7, 2015 08:27 PM
