View Full Version : how many times...
ilovemy8 02-18-2010, 11:47 AM will the renesis take flooding???
i handed over the car to mechanic who took it to the hyundai shop where he works.. did a diaog on it.. says that rotor one its compression is at 78% or something i'll get exact numbers in a bit.. and rotor 2 is at 118.. the minimum he said for each rotor is 98.6
granted my car does have high miles.. almost 110k
and remember i had the flooding Q's in a thread prior to this one..
so changed out coils.. plugs were cleaned.. wires and plugs where not even a yr old yet..
my guy is in contact with the a mazda buddy of his.. hopefully i'll find out something soon i'd really rather not buy a new motor..
but as my question was stated how many times can a the renesis take a flood??
jmc23200 02-18-2010, 11:58 AM The number of floods it can take is not set in stone. Why do you ask? Do you flood it on a regular basis?
The compression test results should come in a set of three numbers per chamber. For example: Rotor 1: x, x, x - shows a result for each face. You should have two of these.
You may want to try an engine decarb. There is a DIY Mazda Zoom Zoom Cleaner thread that will five you the instuctions.
mscamp02 02-18-2010, 12:33 PM you need to get real compression numbers as jmc said in a set of three...
as for the 3 rotor idea....Ill just say it before you get flamed for bringing it up but there are a million threads on this subject and its gonna take a long time and cost 20k plus upwards of 30k if you cant do any of the work
ilovemy8 02-18-2010, 12:38 PM actually i read it.. let me edit b4 i do get smashed on lol... but yeah he did mention after i posted this that his computer is not as accurate as the one mazda is going to have obviously
the mazda zoom zoom decarb.. let me find it
ilovemy8 02-18-2010, 12:40 PM The number of floods it can take is not set in stone. Why do you ask? Do you flood it on a regular basis?
i have flooded it twice n a years time.. but only cuz i was dumb and didnt spend money right n not buy my coils when needed..
ilovemy8 02-18-2010, 12:49 PM well i found the thread about cleaning.. and its recommended to have the car warmed up b4 hand in order to effectivly clean.. my car wont start at all.. that doesnt seem to be useful.. ;(
jmc23200 02-18-2010, 03:50 PM You didn't tell us that unles sI keep over looking it..........................
ilovemy8 02-18-2010, 06:34 PM yur right i didnt mention that but in the prior thread i did.. sorry
yeah my car is not starting...
jmc23200 02-19-2010, 10:57 AM Sounds like you will need a new engine. I had the same problem. The car would crank like a mother, but wouldn't start. If it did start, I could keep my foot to the floor on the accelerator to keep it on and it would only rev to about 2k - 3k rpm. Take the cat off and crank the engine. If you see any oil dripping from the pipe, you are SOL. Or get a real compression test performed.
Razz1 02-19-2010, 11:27 AM Take it to a Mazda Dealer or special rotary shop.
Hyundai mechanics do not know a rotary.
ilovemy8 02-20-2010, 01:20 PM Well the guy was a friend he wants to learn more rotary so I gave him a chance its currently at maDa and I'm awaiting further details.. ill keep ya informed
ilovemy8 02-23-2010, 08:14 PM well i took it in to the stealership.. turns out the battery in my car is too small which didnt help, so it helped with the flooding..
also i needed a new secondary shutter vaule replaced and the intake cleaned out througly..
the only reason i paid 850 is because i dont have any trusted rotary mechanic exept the one in the back of that dealership, the others were not closer than 200 miles..
so i allowed to get that done.. it was gonna be 1200 bux but i talked him down to 850..
so after a 2 month wait i'll be driving my 8 tomorrow home from work.. :)
Chavy 02-23-2010, 09:36 PM what a steal =|
jmc23200 02-24-2010, 08:22 AM So you got a new battery, and the SSV cleaned through the UIM for $850. Unless they showed you the old valve and all of the carbon on it, they cleaned the old one. The SSV valve is notorious for getting carbon buildup and sticking. Dealer says new SSV Valve when in reality you can clean it and it will work just fine. It's kind of like the power steering. When it cuts out, dealer say new rack, when in reality, you most likely need to clean the connector.
ilovemy8 02-24-2010, 10:19 PM the guy that worked on my car is the buddy of my other mechanic friend..
thats why i mentioned "trusted"
but in all reality.. i could have just gotten screwed.. stealership took me wtf'ever i know now.. lol
thanks tho.. seriously. i'll make sure to ask for that particular part..
jmc23200 02-25-2010, 11:15 AM ask to see the old part. It should be COVERED in black sticky carbon.
Dirty
http://www.rx8club.com/attachment.php?attachmentid=151621&stc=1&thumb=1&d=1266203545
Clean
http://www.rx8club.com/attachment.php?attachmentid=151622&stc=1&thumb=1&d=1266203545
