interested in rx8
Old Feb 16, 2010 | 07:00 PM
uahmad87's Avatar
NJ interested in rx8
hi, im interested in buying a rx8, ive been researching abt it on-line i found out that you have to check the oil weekly (thats the engine oil right?). and if the oil runs out how would you put the oil in would it be like a oil change? or you can just put the required amount is there anything else i need to know abt rx8?........PLEASE HELP
Old Feb 16, 2010 | 07:02 PM
jasonrxeight's Avatar
the dipstick has dots on it tell you how much amount of oil is needed.
Old Feb 16, 2010 | 07:03 PM
invasion08's Avatar
The rx8 burns oil. Depending on how you drive the car depends on how much oil is burned. The rule of thumb is to check your oil every other time you get gas. First check your dipstick and see if the oil is low. If low remove the oil cap and add oil until there is enough oil in your engine. Remember not to overfill the oil. Where in NJ are you?
Old Feb 16, 2010 | 07:04 PM
robrecht's Avatar
Also make sure you're prepared for relatively high fuel consumption: 16/22. Worse if you don't take care of your car well. But for most of us it's worth it. The handling and steering response is great. Torque, not so much, but it revs to 9k.
Old Feb 16, 2010 | 08:20 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Wow...perhaps you should look at a car that doesn't require as much proactive maintenance and care like a Honda or Nissan or even a Toyota.
Old Feb 16, 2010 | 09:14 PM
Marklar's Avatar
All you have to do is check the oil once in a while and add a bit when it gets low. People talk about the oil thing like it's some huge burden, but you only need to add like 1/2 to a full quart between oil changes, it's not a big deal.
All you have to do is unscrew the oil cap, stick a funnel in, and pour in some oil when it's low. Don't add too much, you don't have to keep if filled up to max, you just don't want it to get too low. Just keep a quart of oil, a funnel, and some paper towels in the car and you're good to go.
The fuel consumption is more of a legit concern, the 8 does gulp down the gas pretty fast.
You also need to rev the engine up frequently, but that's more fun than work. You also need to stay on top of maintenance, you can't let oil changes slide for 5k miles with this car. Tires need to be rotated frequently, plugs and coils need to be replaced about every 30k miles, etc. It's not a low-maintenance ride, you have to put some time and money into keeping it running.
It's worth it though.
Old Feb 16, 2010 | 09:35 PM
JinDesu's Avatar
went back to srsly broke
Have you ever owned/had a car before?
Old Feb 16, 2010 | 09:38 PM
Xander's Avatar
if your ok with the low MPG buy it and love it..read all about it on this forum...in fact this forum has saved me a **** ton of money it seems no matter what goes wrong w the car somone on here has posted about it and how to fix it.....
Old Feb 16, 2010 | 10:38 PM
cidvicious831's Avatar
this thread=fail!
Old Feb 17, 2010 | 05:45 AM
uahmad87's Avatar
Thanks everyone
Old Feb 17, 2010 | 09:02 AM
ken-x8's Avatar
Originally Posted by cidvicious831
this thread=fail!
Why would you say that? uah came in with an honest question. He got a friendly response with good answers. I'd say that this thread passed with high honors.
Ken
Old Feb 17, 2010 | 03:21 PM
Roaddemon's Avatar
Mine burns a quart every 3k miles. If you are an idiot , neglectful and forget to check the oil, an idiot light will light your dash to remind you that you are an idiot, and a quart low. (It has happened) Stop as soon as convenient and add the proper amount of oil as indicated on the dip stick.
Skyl3r
Dec 2, 2019 04:51 PM
SUKIEE
Oct 9, 2017 09:41 PM
Mazdakevin
Mar 10, 2016 12:32 PM
TheAlbinoRhino
Aug 4, 2015 09:48 PM
