Synthetic oils.
Old Feb 15, 2010 | 06:05 PM
xxtonezxx's Avatar
Synthetic oils.
I've been changing the engine oil in my iRX8 for years and I never knew I wasn't suppose to use synthetic in them rotaries. I kinda felt the engine was lagging. I've probably done damage to it now. But my question now is should I immediately change to minerals based after so long? Engine seems fine. I take very good care of it despite this. I've changed the oil every 3000 miles. I ALWAYS warm it up before I drive anywhere no matter what. What damage could I have done to it?
Old Feb 15, 2010 | 06:10 PM
invasion08's Avatar
More information and FAQs on lubrication of rotary engines.
In a rotary engine, the oil lubricates the eccentric shaft bearings, thrust needle bearings and rotor bearings (similar to a crank and rod bearing of a piston engine). It also is injected into the combustion chambers to lubricate the apex seals, corner seals, and side seals, all of which helps to create the sealing mechanism (the equivalent job of the piston rings).
Royal Purple provides outstanding protection for the e-shaft, rotor bearings and thrust bearings and is suitable for the oil injection system as it has proven to run cleaner than other oils and is an excellent choice for rotary apex seals, corner seals and side seals.
Mazda makes a statement in the Owner’s Manual not to use synthetic oils in a rotary engine, why do you say that it is OK?
Royal Purple has performed seal compatibility testing on the components used in a rotary with excellent results — including older rotary engine seals dating back to the Cosmo. Royal Purple’s Technical Services Manager David Canitz (who has been an owner and racer of rotary engine cars using synthetic motor oils since 1985 with excellent results) has been trying to find an answer to this Mazda statement for the last 18 years.
In the early development of synthetic oils decades ago, there were purportedly some seal compatibility issues. Today’s synthetic oils do not have the compatibility issues of the old oils. There is no substantiated evidence of seal compatibility issues with Royal Purple.
Here are some facts:
•The Mazda Factory racing departments recommend and use ‘synthetic’ oils including the winning 1991 Leman’s 20-G 4 rotor Mazda 787B.
•MazdaComp USA printed manual (now Mazdaspeed) recommends the use of synthetic oils for racing conditions.
•Royal Purple Motor Oils have been used in rotary engines (both race and street) for 10+ years with excellent results.
•Royal Purple Motor Oil is compatible with the bearing material, sealing elastomers and combustion seals used in a rotary engine.
I heard that synthetic oil doesn’t burn like mineral based oils and will coat the inside of the engine with deposits. Is this true?
If this was a problem with synthetic motor oils in general, then all internal combustion engines using a ‘synthetic’ would experience increased deposits on internal surfaces. The opposite is actually the norm.
Conventional four-cycle motor oils will typically leave deposits of carbon and ash when injected into the rotary apex seal, corner seal and side seal areas. Royal Purple’s motor oil burns cleaner due to its synthetic base stock being free of contamination and the fact that many of its additives are ‘ashless’. This may not be true for all synthetics but Royal Purple has been proven to work extremely well in rotary engines.
Royal Purple’s formulation of synthetic hydrocarbon motor oil burns at the nominal combustion temperatures experienced in both street and racing applications, whether normally aspirated, turbocharged or supercharged. (500 – 1700%°F idle to race rpms typical combustion temps)
Will the synthetic oil affect the oil seals?
No. Royal Purple’s motor oil is fully compatible with the elastomers found in rotary engines as well as more conventional piston engines. The oil seals, housing seals and other elastomers used in rotary engines typically consist of Buna N, Nitriles, Neoprene or Viton materials, which are also commonly found in piston engine cars.
I hear that synthetic is ‘thinner or lighter’ oil. Is there a greater possibility that the oil will leak between the seals?
No. If an engine’s sealing surfaces are in good condition, synthetic oil should not cause any leakage. However, if an engine has marginal seals, there is a 50/50 chance the seals will leak. A synthetic motor oil is going to have similar viscosity to that of a conventional motor oil – except at extreme temperatures. Due to a flatter viscosity curve, at low temperatures it will not thicken as much (easier winter cranking) and will not thin out as quickly at higher operating temperatures (better oil film at higher rpm).
Old Feb 15, 2010 | 07:07 PM
RX8pwnage's Avatar
RX8. Yeah, I get it.
word for word from royalpurple.com!
Old Feb 15, 2010 | 07:13 PM
HockeyRX-8's Avatar
TNC
Synthetics are perfectly fine in a rotary
Old Feb 15, 2010 | 09:44 PM
ken-x8's Avatar
Please don't make that a blanket statement. They made no such statement through 2006. It looks like they do have that from 2007 onward.
Ken
Old Feb 16, 2010 | 05:40 PM
CyberPitz's Avatar
Huge hole is huge
I wonder why they would wait until 07 to put it in, even when it's really not a bad thing....
Old Feb 16, 2010 | 05:49 PM
TX
Yep, don't believe the hype. Most modern day oils are good, just a name brand and change it often.
Old Feb 16, 2010 | 05:55 PM
zoom44's Avatar
read the other oil threads for more info. thread closed
RAE008
Sep 12, 2015 09:08 PM
Cookingislife1226
Sep 5, 2015 03:38 PM
wayloco
Sep 1, 2015 09:03 PM
cschoeps
Aug 6, 2015 12:44 PM
RotaryRider
Jul 20, 2015 07:05 AM
