KW varient 3 settings?
Old Feb 13, 2010 | 09:40 AM
olddragger's Avatar
Ok --finally bit the bullet and got a fairly decent street/track coilovers.
I had been running the konis with aftermarket springs.
dannobre has given me some settings he has been using and that is much appreciated. but, I thought I would ask others also
I like the rake i had with the konis.
i dont want to hit the bumpstops.
I run a 275/35/18 wheel/tire and have rb bars and endlinks.
OD
Old Feb 13, 2010 | 11:35 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Can't answer your question, but am interested in the responses you get. I have wanted these for quite some time now and haven't bit the bullet, so I'll be watching this.
At least it's a free bump to keep it active!
Anybody............Bueller............Bueller?????
Old Feb 13, 2010 | 12:13 PM
Polak had these, maybe you can reach him before he goes MIA again.
Didn't Razz have these as well?
Old Feb 13, 2010 | 12:47 PM
TopGear8's Avatar
mkuhnracing.com
Razz has them and GeorgeH has them and uses for Autox use, but has not done any Road course events on them, which is mainly what OD will use them for.
Old Feb 13, 2010 | 01:17 PM
Highway8's Avatar
Registered RX8 Nut
I also have the KW varient 3 coilovers and use my car for both street and road courses. I run the progress tech sway bars with the middle setting on the front and the firm setting on the rear. I also run 275/35/18 r-comp tires at the track.
I would suggest you lower the car approximately 1" and then get it corner balanced. For the Compression and rebound use the recommended setting from KW and adjust it from there ( I always firm everything up 1 turn for the track) because with all suspension settings, what works for one person may not work for someone else. Also, I dont have cables to attatch to top of the rear strut, so I can not adjust the rebound in the rear. I believe I have it .5 turns past the recommended setting.
I am pretty sure with a 1" drop and the recommended setting, you wont hit the bumpstops.
Good luck and if you dont already adjust your alignment I would suggest you get an alignment kit and play with it at the track.
Old Feb 14, 2010 | 09:05 PM
olddragger's Avatar
thanks highway--- i hear ya---been running good alignments for a long time. The shop has my settings on a "special file" lol .
Corner balancing will be just a little later after it all has settled.
I was surprised that the sways end links had stiffened some--front and rear.
suspension is installed and it feels SO much better than the konis and tein h's
basically kept the same rake as i had. approx 1 " drop on the front and about 1/2to 3/4 in the rear. recommended rebound and compression at present.
its a new world and I already had too much to do.
OD
Old Apr 2, 2010 | 11:02 AM
ganseg's Avatar
Nature vs. Nurture
OD - since yours were used, like mine, did it settle after install? I was planning to have the install, corner balance and track alignment all on Monday. Also what initial setting do you recommend? I want to go more aggressive than KWs because I want to get set up for my first track event in a month. Thanks.
Old Apr 6, 2010 | 01:26 PM
ganseg's Avatar
Nature vs. Nurture
Got mine installed with most of ODs settings and it seems very good. I have a question though:
Anyone with KW3s and the separate resevoirs? I could not figure out how to adjust the bump settings on my rear dampers, which have the resevoirs. There is an allen headed screw in the end cover of the resevoirs, but it backs all the way out, so I don't think it is for setting a valve.
My fronts are the newer kind with no resevoir and I was able to adjust those. Thanks for any help someone can offer.
Old Apr 6, 2010 | 06:13 PM
Highway8's Avatar
Registered RX8 Nut
I have resevoirs on both the front and the rear and the compression is adjusted with a little silver colored tool. you remove the black cover on the base od the strut and you will see small shaft with holes in it. you put the tool in and turn it in either direction 90 degrees at a time.
Old Apr 6, 2010 | 07:00 PM
ganseg's Avatar
Nature vs. Nurture
Just what I needed to know - thanks! Do you think that some other tool would work? I bought mine used and did not get that tool with it...
Old Apr 6, 2010 | 07:57 PM
Highway8's Avatar
Registered RX8 Nut
you should be able to get something else to work. The diameter of the tool I have is a little larger then a paper clip.
Old Apr 7, 2010 | 04:49 PM
ganseg's Avatar
Nature vs. Nurture
From the center of the hub to the corner of my fender directly above is 13.75 front and 13 rear. It seems to vary somewhat, but this is an approximation. Interestingly, the height adjusters on my rear coils are all the way at the bottom, which would indicate the rear is as low as it can go. That seems strange to me, but i don't want to go lower anyway.
Highway8, are your rear height adjusters at the bottom?
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
