wtb power steering module
Old Feb 11, 2010 | 04:37 AM
Ronaldl33's Avatar
MA wtb power steering module
Looking for a power steering module , the dealer wants 1200 and thats just out of the question!!cant find this part anywhere
Old Feb 11, 2010 | 06:53 AM
KrumbZ's Avatar
1.3L of Fury
whats wrong with your steering module?
Old Feb 11, 2010 | 07:40 AM
expo1's Avatar
He's as bad as Can
Try Mazmart for that part/
Old Feb 11, 2010 | 07:45 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
PMed
Old Feb 11, 2010 | 05:10 PM
Ronaldl33's Avatar
MA yeah
the steering wheel its hard and the dashboard light came on, so i took to mazda and they told me i had to replace the eps module i'am not sure how that looks but yeah thanks guys for the quick reply
Old Feb 11, 2010 | 05:11 PM
rotoryfan1991's Avatar
I got one PM me
Old Feb 11, 2010 | 05:53 PM
Tweek's Avatar
RobotsToRobots.com
Could the hard steering have anything to do with the steering fluids?
Just taking a guess.
Old Feb 11, 2010 | 05:55 PM
dozer's Avatar
on his 3rd rx8
^its electronic, no fluid needed....
to the OP, have you tried cleaning out the connectors?
Old Feb 11, 2010 | 06:07 PM
Tweek's Avatar
RobotsToRobots.com
Ha, looks like i need to study a little more.
Old Feb 11, 2010 | 06:10 PM
Jon316G's Avatar
Grasshopper
Much cheaper and easy to change out yourself:
http://www.mazmart.com/PartsList.aspx?id=17&n=USED&m=6
And I agree with Dozer on cleaning the connectors under the air box.
Old Feb 11, 2010 | 06:21 PM
dozer's Avatar
on his 3rd rx8
cleaning the connectors is an easy fix, takes about 20 minutes of your time, and if you do it right everything should be fine
Old Feb 11, 2010 | 06:55 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Dozer is right...............gotta try those connectors before just assuming it's the module.
Let me find that thread with the nice pic in it to show you where the connectors are!
Here it is!
Read this thread fully. https://www.rx8club.com/showthread.p...light=steering
Old Feb 11, 2010 | 10:04 PM
Ronaldl33's Avatar
MA thanks
thanks for all the replys iam gonna try to clean the connectors before anything else then hopefully it works
Old Feb 12, 2010 | 07:34 AM
Mazurfer's Avatar
^................Make sure you let us know, so we can use it as a further reference. Hopefully that will be it!
Contact cleaner is the way to go, but get them clean and dry. If it works, then start thinking about lengthening that coolant overflow hose!
Just don't go by what the dealer tells you.
Old Feb 12, 2010 | 11:44 AM
Ronaldl33's Avatar
MA
hey guys i looked at the pic of what iam suppose to be looking at and today i open the hood any advice where the connectors are next to looks kinda complicated im no mechanic lol
Old Feb 13, 2010 | 11:17 AM
Mazurfer's Avatar
So, you looked at this pic?
It's the gray connectors and they would be really hard to see as they are located pretty low.
The best way to find them is to take out the intake box to give you good access to them.
If you aren't sure about how to do that or don't feel like you can attempt it, then find someone who can.
Print this picture out, give it to them and point!
Have them unplug these connectors, clean the contacts real good and plug them back in. This would still be well worth it if it cures the issue.
Old Feb 13, 2010 | 11:35 AM
expo1's Avatar
He's as bad as Can
Old Feb 13, 2010 | 11:38 AM
Mazurfer's Avatar
^.............great pic!
Will use for further reference!
Funny how I get used to people's avatars and when they change I'm like................WTF?
Old Feb 13, 2010 | 12:28 PM
OSducky's Avatar
in some cases it's not the connectors ............. trust me I wish it were the connectors =[
Old Feb 13, 2010 | 01:06 PM
hakuna matata!
http://newyork.craigslist.org/que/pts/1597723619.html
Old Feb 13, 2010 | 01:12 PM
Mazurfer's Avatar
Of course it is not always the case, and we pointed that out, but it's certainly worth the effort to try it first before moving onto the module or the entire steering rack!
Old Feb 14, 2010 | 05:20 AM
Ronaldl33's Avatar
awesome
thanks for the pic just what I need it gotta print this out
Old Feb 14, 2010 | 07:15 AM
CTrx8's Avatar
space for rent
check your battery connections too. i had one that got corroded and when i replaced that, i was good to go. probably not the culprit but worth looking at them anyway.
Old Feb 14, 2010 | 07:26 AM
Mazurfer's Avatar
^...................yeah, I think the goal here should be to eliminate most(if not all) of the easy possibilities before going after the module or the rack itself.
Old Feb 15, 2010 | 12:34 PM
Ronaldl33's Avatar
today
today I'll be doing the cleaning on the connectors I'll let you guys know how it went
