Spark with no ECU
Old Feb 11, 2010 | 04:37 AM
parny's Avatar
Spark with no ECU
Hi, i am putting a 2005 13b 4 port in a jet ski, i dont have the engine loom or ECU, i have made up a carb manifold with webber twin 40s, i have all ignition coils and crank position sensor, is ther anything i can make or anything i can buy( i am electronically minded and can prototype) that will give me a spark and what are the angles of spark and firing order, is it 120deg per rotor housing and what angular difference is ther between the two rotors and how far after TDC do i need the spark??? hopefully someone can help, i am a crazy english guy!!
Old Feb 11, 2010 | 06:28 AM
alnielsen's Avatar
Because there is no distributer on the engine, you are going to have to have some sort of ECU to make spark and to make changes to the timing. Since you don't have a fuel injection system anymore, I think that the Mega Squirt ecu may be the best option.
There is a RX8 club in the UK with some very talented people. They may be able to help. Here in the US, there are marine ready (RX7 type) 13B's available.
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
Oct 3, 2015 09:51 AM
Jb4ker96
Sep 27, 2015 10:06 PM
