Best Aftermarket Battery
Old Feb 11, 2010 | 03:13 AM
huckfarper's Avatar
Question Best Aftermarket Battery
It's time to replace my battery, so...
What is the best aftermarket battery that delivers the most cold cranking amps, fits our cars, and otherwise makes you think that battery is the best. Please explain why in your response.
Old Feb 11, 2010 | 03:21 AM
Click here for the best ...
Old Feb 11, 2010 | 03:22 AM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Old Feb 11, 2010 | 03:26 AM
ZumnRx8's Avatar
RX8 & RX7 owner
^LOL@ TEAMRX8... im Going to use that now LAWLZ!!!!!
but in reality.... OPTIMA DRYCELL.... I have the Yellow Top... I suggest you get the Blue TOP
Old Feb 11, 2010 | 03:54 AM
huckfarper's Avatar
Well I guess I should have said I already searched and found conflicting information in the threads (based on price, CCA, etc.) This is why I asked for people to explain their rationale.
Thanks for reminding me that I needed to state that in my post, TeamRX8.
Old Feb 11, 2010 | 08:52 AM
Originally Posted by TeamRX8
thats my line you ***.
only I can tell people to search !
Anyway, this is the best battery money can buy
Old Feb 11, 2010 | 09:05 AM
nx04's Avatar
zoom-zoom
lmfaoooo
Old Feb 11, 2010 | 09:51 AM
ZumnRx8's Avatar
RX8 & RX7 owner
No.... seriously though...
For Racing/Track- Braile Batteries are your best choice
For Aftermarket Electronics (radio, tv's neon, subwoofer) - Optima Yellow Top.
For Performance/Track - OPTIMA Red Top
If you plan on making your car into a boat- OPTIMA Blue Top
Old Feb 11, 2010 | 11:02 AM
I agree..
I think the Moderators should give Team a warning.
Sears Die Hards and Interstate batteris with enough CCA for your car is fine.
You don't need a special battery for your car unless you track it or have a BIG Boom box.
Old Feb 11, 2010 | 11:24 AM
Nubo's Avatar
Lubricious
In terms of reducing maintenance hassles to zero -- get an AGM battrey (absorbed glass mat).
In terms of capacity, CCA is not a great yardstick. Look for reserve-hours, or amp-hours. If the mfr doesn't give those, screw 'em.
In terms of longevity, deep-cycle capability gives you insurance against battery damage in the event of deep-discharge. Something to consider if you park for extended periods, or like to run audio equipment with the car not running, or would just like to be able to recover from a flood without toasting the battery in the process.
Don't use a battery size larger than group35; for airflow and cooling considerations.
My recommendation for anyone who's not weight-conscious is the Sears DieHard Platinum P5, Group 35. This appears to be a re-branded Odyssey. Well-respected deep-cycle battery company, AGM, no leaky, good amp-hours and reserve capacity, great warranty, fits, easy to find.
If the cost bothers you, consider you're talking less than the price of a tank of gas per year over the life of the battery. Not a big deal, and you did say you're looking for the best.
For a bang-for-the buck approach get the cheapest brand-name battery you can find. It'll work, and as long as you deal with the maintenance and don't deep-discharge it, will give reasonable service.
Old Feb 11, 2010 | 11:26 AM
Vlaze's Avatar
The Angry Wheelchair
For a DD long term use, I'd suggest Diehard Platinum. They have a warranty of 4 years contrast to Optima's 1 year for a yellow top.
But whatever floats your boat
*edit*
Looks like an Optima yellowtop non commercial battery has been bumped up to 3 years now (36 months) from what I read.
Old Feb 11, 2010 | 01:18 PM
EDZRIDE's Avatar
2005 White GT
+1 on the above advice.
Old Feb 11, 2010 | 01:28 PM
Huey52's Avatar
Registered Zoom Zoomer
I've been 'round and 'round on this planning myself, but have to say the OEM Interstate has served me very well and I'll probably just re-up with that one when the time comes - still crankin' strong going into its 5th year.
Old Feb 11, 2010 | 01:40 PM
I've had an Optima Yellow Top for 4 years now and it's a stud. I've run the battery quite low with my 1400 watt amp and dual subwoofers and it keeps on going.
I let my car sit for almost a month in the garage and it still started up.
"Best" is such a subjective term that you'll never get a "true" answer on it as we all have different requirements / demands of our batteries. (Cold cranking, deep cycle, longevity, etc)
Old Feb 11, 2010 | 02:39 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Yellow Top- FTW!!!!
Old Feb 12, 2010 | 04:06 AM
Really? Mine died in under a year. It was the best POS I ever owned. That it had a warranty was meaningless because it has to be sent back for inspection which in the meantime meant I was dead in the water. Replaced it with an Odyssey, which was carried locally, and never looked back.
This is why you get conflicting data. What exactly defines best; best price, best value, best quality, etc.? Not to mention, what makes you think any one here has a clue about what is "best"?
In other words, you asked a conflicting question. How could you expect a clear answer. It's just a battery, not a life planning event. Go down to Walmart, keep your receipt, and don't waste your time over-thinking such trivialities.
Old Feb 12, 2010 | 04:26 AM
Chad D.'s Avatar
Spinnnnnnnnnnn
I would suggest an optima red or yellow top
Old Feb 12, 2010 | 04:35 AM
wow,
thread full of fail..
team states if right.. op.. you are where?
the right battery is like beer.. right place right time..
the correct battery will start the car when it needs to be started.. how hard is that..
cant wait to see you post in i flooded my engine thread..
Old Feb 12, 2010 | 05:37 AM
ken-x8's Avatar
For a DD long term use, I'd suggest Diehard Platinum. They have a warranty of 4 years contrast to Optima's 1 year for a yellow top...
No need to spend a lot of money for a long warranty. For $50 to $60 (less if you catch a sale) you can get a battery from Advance Auto or similar places, with a 5 or 6 year warranty, full replacement for the first one or two years.
That would be a conventional battery that does need to have its electrolyte level checked every now and then. Since the 8's battery is buried under under a cover, it might be worth spending more for a maintenance free battery.
Ken
Old Feb 12, 2010 | 06:27 AM
Vlaze's Avatar
^It wasn't just for the warranty but also the fact that I've never had a Die Hard fail on me *looks for wood to knock on*
And they are maintenance free
Old Feb 12, 2010 | 07:55 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Ken
Where is your full replacement when the battery dies on you on the road? Or when you stop to put gas a gas station in the night, your battery fails & there is no Autostore around, especially the same Autostore that carries your warranty on your battery? Drycell FTW
Old Feb 12, 2010 | 03:00 PM
ken-x8's Avatar
I'm going to lie awake nights worrying about that.
Speaking of nights... a couple of times I bought batteries at an all-night drug store. Kind of cool. Batteries were dry, with a bag of acid I had to pour in myself. No worry about how long the battery had been sitting on the shelf before being sold. One did die on me late at night. I was able to get it replaced some time after midnight. Had I been reckless enough to buy a Diehard, I'd have been stuck waiting til Sears opened in the morning.
Ken
Old Feb 12, 2010 | 03:02 PM
chino0314's Avatar
this thread is a joke lmao i laughed on every link
Old Feb 13, 2010 | 01:39 AM
Nubo's Avatar
Lubricious
I'm here 'till Thursday. Try the veal.
Old Feb 13, 2010 | 06:07 AM
huckfarper's Avatar
For those wondering, I live in Calgary, Alberta, Canada. I occasionally drive up north where it gets really cold. I'd prefer not to have to post in the "flooded" thread.
Thanks for all the advice.
