Center Exhaust?
Old Feb 8, 2010 | 10:19 PM
BigC94's Avatar
CA Center Exhaust?
I was thinking of doing a center exhaust set up that would have a triangle tip coming out of the rotor symbol in the back bumper. Have any of you seen something like this? I have searched and did not find any results. It looks pretty easy to do. What issues do you think I would have doing this?
Old Feb 8, 2010 | 10:29 PM
chino0314's Avatar
mock up
https://www.rx8club.com/showthread.p...center+exhaust
Old Feb 9, 2010 | 02:30 AM
tiltmode43's Avatar
OMGITM!
It's been done by a few members; I'd be wary of melting the black portion of the bumper. You'll have to cut a good distance around to prevent this from happening and that in itself may detach from the aesthetic look you're going for.
Old Feb 9, 2010 | 09:15 PM
BigC94's Avatar
Thanks for the links and inputs. The melting issue is my major concern and then the amount of surrounding material needed to be removed and the sagging effect afterwards. Thanks again
Old Feb 9, 2010 | 09:52 PM
HaydonGS's Avatar
Lurker
You could use something like gold reflector/heat resistors (I've seen this a couple places like in the engine bay of the Mclaren) but maybe that would keep it from melting the plastic.
Old Feb 9, 2010 | 09:57 PM
ZumnRx8's Avatar
RX8 & RX7 owner
KNIGHTSPORT & RACING BEAT is your friend & yes its been done
Old Feb 9, 2010 | 09:59 PM
two zero two's Avatar
Unregistered User
i've been thinking about doing this too.
my plan was to get the kenstyle rear and doing a RE Amemiya/greddy rx7 thing with the exaust
exhaust setuphttp://www.youtube.com/watch?v=kd1lhW0UnE8
and do that through the section below the license plate here
Old Feb 9, 2010 | 10:04 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^copy cat (same here)
Old Feb 10, 2010 | 02:39 AM
ЯX-8's Avatar
You can forget your triangle tip idea, because the tip will be tiny. You'd have to cut out the triangle completely, so you could have an exhaust tip sticking out far enough, so it won't melt the plastic.
Old Feb 13, 2010 | 10:30 AM
BigC94's Avatar
What exhaust is this? This is exactly what I wanted to do. The tip size would be an issue if it was the triangle, but this looks good!
Old Mar 31, 2010 | 10:16 PM
BigC94's Avatar
Well I did it... Works great and only took about 2 hours and cut a bunch of weight. Sounds great and cured the high rpm stumbling issue I had.
Attached Thumbnails Center Exhaust?-exhaust-1.jpg   Center Exhaust?-exhaust.jpg
Old Mar 31, 2010 | 11:45 PM
dsire4u's Avatar
SS RX8
video??
let me hear your sound man.
Old Apr 1, 2010 | 12:18 AM
MaRxtin's Avatar
idk i think it would only look right if it fit on the triangle part
Old Apr 1, 2010 | 06:23 AM
Rotr8's Avatar
whines all the way home
not my cup of tea, but at least the contours of the bumper make it look like it was made for that area, and it looks pretty good too.
Old Apr 1, 2010 | 06:24 AM
BigC94's Avatar
I only cut out the triangle for the exhaust hole and the oval Borla tip I used fit right in. It all fits pretty clean and was a no brain mod. I agree a rotary shape tip would look good. I'll post video and sound clip and better pics soon.
Old Apr 1, 2010 | 06:30 AM
BigC94's Avatar
Thanks, it is different and that is what I was going for. It is hit or miss with friends of mine whether they like it or not. The factory cut out in the bumper helps it have a finished look. I still need to mesh the stock openings.
Old Apr 12, 2012 | 12:11 AM
SPD-FC's Avatar
Pics of the one we did in 04 with the rotor tip
It's ,a few posts down
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/some-pics-caage-we-built-rx8-37986/
Old Apr 12, 2012 | 12:43 AM
Looks nasty dude, "race car" or not.
Old Apr 12, 2012 | 01:35 AM
EricB's Avatar
#225 of 1000
Old Apr 12, 2012 | 09:47 AM
SPD-FC's Avatar
It was finished up nicely back in 04 I just lost the pics Of it done
Old Apr 14, 2012 | 12:29 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Never knew there was a thread about this...lol
Anyway, center exhaust looks stupid to me...just my .02 cents.
Old May 2, 2012 | 02:05 PM
brilliantblackrx8's Avatar
Old May 13, 2012 | 11:08 PM
oki josh's Avatar
I want that muffler !
Old May 14, 2012 | 09:41 AM
shakeyourbrakes's Avatar
Even with the kenstype I think it'll look stupid. Unless you get rid of the exit ports on any bumper it'll look like it was just stuck in there. That's why that rx7 with it looks so good, it was made for that exhaust
Old May 14, 2012 | 10:27 AM
ooobigfire's Avatar
I wonder.. Mabye take off the bottom half (unpainted part) of the rear bumper. Just cut it completely off... the more I think about it the more I think it wouldn't look too bad if done properly. Any one got a spare rear bumper? doesn't have to look good and bottom can be torn to shreads lol.
