quick question....
Old Feb 7, 2010 | 11:12 PM
RX8sd's Avatar
quick question....
I went to clear the codes on my access port. The cell dissapeared but on my accessport it still said RKE...and below that....P0000. Anyone know what that means? Probably nothing....but I was just wondering
Old Feb 7, 2010 | 11:19 PM
@!!narotordo's Avatar
FLAME ON!
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Old Apr 10, 2010 | 03:59 PM
waterproofone's Avatar
ROTORHEAD
I have the same thing and don't know what it means either.
Old Apr 11, 2010 | 06:11 PM
TipOver's Avatar
I found a link with generic trouble codes starting at P0001 and up. Perhaps P0000 indicates no problems?
http://www.obd-codes.com/trouble_codes/
Old Jul 25, 2010 | 03:12 PM
Rocketman1976's Avatar
Tailgaters beware
Originally Posted by @!!narotordo
P0000 isn't in there.
Old Mar 30, 2012 | 04:42 PM
longpath's Avatar
Did this ever get identified?
Old Apr 19, 2012 | 12:45 AM
Imperium612's Avatar
FL
P0000 (Non MIL Code) No Self Diagnostic Failure Indicated
In other words.. your fine
Old Apr 19, 2012 | 11:42 AM
tofu_box's Avatar
i got P0000 on my scangauge 2, when i plugged into a ford/mazda diagnostic equipment it showed rear o2 sensor stuck lean error code. Maybe its worthwell to try and use a factory diagnostics if you have access to one.
Old Apr 19, 2012 | 12:25 PM
wcs's Avatar
wcs
no agenda
I can RKE 1900 code all the time
I think it has something to do with the Canbus
But really I have no idea what's causing it
Old Apr 20, 2012 | 07:35 AM
The P0000 means no self diagnosing equipment on the 8 is reporting any trouble to the ECU, if you got a
Code showing rear o2 lean error, but all you saw was a p0000 present, then it was a CEL that HAD been thrown by your midpipe (possibly a P0420) which I'm taking it you have cuz if you got that with a Stock CAT then that means it already failed and them some. The P0000 without any other codes means everything is OK.
When you get a rear catalyst or O2 code from a midpipe, the code will appear with the P0000 also cuz even
Thought thats reporting a problem, none of the rest of the car or any major components are reporting a code
The brand of code reader makes no differance, factory/dealer/local shop.. all the same
Brokegang
Jan 3, 2016 12:45 PM
runningmann
Good Guy/Bad Guy
Sep 19, 2015 09:15 AM
Randolph Alvarez
Sep 14, 2015 04:25 AM
RXBae
Sep 14, 2015 03:54 AM
