want to get new set of rims but questions
Old Feb 4, 2010 | 03:33 AM
dsire4u's Avatar
SS RX8
hello,
its finally time for me get new set of rims.
but i have to curious questions.
I already looked into the sticky "Effects of Wheel Size/Weight on Performance "
but lot of the links are not working
so i couldn't find the clear answers to my questions
so i am writing this post.
I am looking at the rim
that is 19", 8"wide, +38, around 20~22lb each.
my question is
what will be the pros and cons getting this rim?
please help me out.
thank you!
Old Feb 4, 2010 | 03:46 AM
J8635621's Avatar
Pew Pew Pew
It will be 19" and sit 12mm farther out. Basically that's it besides they look different. Weight is negligable.
Old Feb 4, 2010 | 12:01 PM
You sure you dont want a wider rim? I have 19x9 +40 and it ways 22.5lbs. It would look great with 10mm spacers...
Old Feb 4, 2010 | 08:22 PM
dsire4u's Avatar
SS RX8
so no more pros and cons?
it's just the same???
dsire4u's Avatar
SS RX8
i wish, but larger the rims, more expensive.
i can't afford...........
Old Feb 4, 2010 | 08:43 PM
TrochoidMagic's Avatar
is adjusting valve lash
so you want expensive wheels, that are gonna also need expensive tires?
another drawback of large rims is the low profile tires u need to match oem diameter, which are prone to bending a rim holding less air...
there are pros to having larger rims... i just can't think of any at the moment. i prefer wider, personally.
Old Feb 4, 2010 | 10:42 PM
dsire4u's Avatar
SS RX8
yea, i want myself a wider rims, but its all about to price for me
since i am a student right now.
i don't want expensive rims, since i can't afford.
right now, i am at the stage the i am trying to find pros and cons of getting 19"
haven't decided between 18" or 19".
Old Feb 5, 2010 | 04:07 AM
J8635621's Avatar
Pew Pew Pew
19" tires are considerably more expensive.
Old Feb 5, 2010 | 01:26 PM
^ This man speaks the truth. Im going back down to 18's because 19" tires are just too much now. I'd trade you my 19's and tires for your stockies but youre in Canada...
Old Feb 5, 2010 | 01:31 PM
2tone's Avatar
The RX-8 is missed
yeah, if money is your biggest factor why on earth would you get 19 inch rims?? big price difference between 19 and 18. stick with 18's.
to answer your question more directly:
stock is 18 x 8 +50 (i think)
your question is 19x8 +38
so yeah, the only difference is it's one inch bigger in diamater and pushed "out" 12mm. same width, and about the same weight as stock. but 19 inch wheels and the matching tires will cost you significantly more than 18's. get 18's, maybe go to 8.5 or 9 inch width and it'll still be cheaper.
Old Feb 5, 2010 | 02:50 PM
TopGear8's Avatar
mkuhnracing.com
The only Pro of a bigger(19" rim) would be to some people, bigger rims look better...
They cost more
They weigh more
The tires will cost more
You will have to worry more about pot holes..
Yeah looks like you should stick with 18's.
Old Feb 5, 2010 | 03:32 PM
dsire,
i'd personally stay with 18s, and get some wider rubber/rim to fill in the wheels.
i'm sure a 18x9 is easily fitted onto the rx-8 if you ask around on what offset to use, if u wanna stay away from rolling your fenders.
you've got some options if you stay 18s. but you have a lot MORE options if you go down to 17s, and cheaper ones at that. i will soon be on two different sets of 17s for different purposes.
BTW,
to help you out. discount tire direct is having a rebate on azenis rt-615s. thats $100 right there!
Old Feb 5, 2010 | 04:41 PM
Rotational mass is different. It's worse so it effects handling, braking and acceleration plus extra wear and tear on the bushings.
The comfort in the ride is a big difference to some people.
Old Feb 5, 2010 | 11:06 PM
dsire4u's Avatar
SS RX8
ah~~,
i am going on to 18" side however i still can't let go of the look of 19".
thanks for your help guys!
Old Feb 6, 2010 | 10:07 AM
2tone's Avatar
The RX-8 is missed
Originally Posted by dsire4u
ah~~,
if you stay with 18's but get lower profile tires than stockers and lower it, it'll have the same "look" as 19's. that sounds weird, but you get it...you can get that same super-low-profile look of 19's but stay with 18's.
projectr13b
Mar 1, 2019 09:00 AM
mariohardleft
Feb 6, 2016 12:59 PM
michaelsk8er
Nov 9, 2015 07:06 AM
bulletproof21
Oct 20, 2015 08:53 PM
AussieGray
Jul 16, 2015 03:58 AM
