Clutch Pedal Vibration Diagonosis !
Old Feb 2, 2010 | 08:45 PM
DavidSkizzle's Avatar
I have a 2004 RX8.
I recently have been experiencing clutch pedal vibration.
This vibration is pulsing and only exist when I'am releasing the clutch i.e Shifting to a gear and then releasing the clutch...Thats when i feel it.
No vibration when putting it into neutral and releasing and also no vibration when just pressing in and out of the clutch. No werid noises. The vibration kind of got worse over the week. The car does not shake and I just wanted opinions on what's wrong and how much this might cost to fix.
ALSO a problem with my shifter. 1st and 2nd gear feels loose compared to 3,4,5,6. It shifts fine and its still smooth but it feels fragile and just worries me.
Old Feb 2, 2010 | 08:58 PM
expo1's Avatar
He's as bad as Can
How many miles on the clutch? The pedal brackets on our cars are also known to break at the welds, yours could be on its way out.
Old Feb 2, 2010 | 09:18 PM
Not sure about the mileage but clutch isnt slipping if that matters. If the bracket is the problem do you know the outcome of it. As in the price for parts/labor. I have no warranty.
Old Feb 2, 2010 | 09:20 PM
Old Feb 2, 2010 | 09:26 PM
expo1's Avatar
He's as bad as Can
One vendor here has TWO options for you. If you know someone that welds you can have your pedal fixed. I purchased a fixed pedal from BHR but I am not sure if they still offer that service.
Old Feb 2, 2010 | 09:38 PM
Is this something that should be immediately fixed?
Old Feb 2, 2010 | 09:56 PM
expo1's Avatar
He's as bad as Can
If your clutch pedal snaps you are stuck, will not be able to shift into gear. But I am not saying that is the cause of your issue. It is just a known problem that even NHTSA is looking into.
If you get it fixed yourself the below thread will be helpful.
https://www.rx8club.com/showthread.php?t=183972
Old Feb 3, 2010 | 08:36 PM
Important
You, most likely, have "hot spots" on your flywheel surface. Kinda like the hot spots brake rotors get, which cause a pulsing brake pedal. This can be fixed with a flywheel resurfacing.
Something I should get fixed right away?... Probably not a cheap fix
Old Feb 3, 2010 | 08:37 PM
Any ideas on my shifter problem?
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
