air pump,please help!!
Old Feb 2, 2010 | 01:31 PM
yellowrx8cy's Avatar
Hi guys!one of my friends has an 8 with 45k miles,192 ps,with new battery,sparks and coils.the problems are two:
1.the air pump is starting before turning on the engine,thing that is defenetly not normal!What could it be?
2.the car has a very jerky start when cold,allmost impossible!to start nedds over 10 cranks!
on hot engine the problem dissapears!!!air pump does not start before time,and engine fires up like new!what could it be?
Old Feb 2, 2010 | 04:34 PM
MazDangerous86's Avatar
Mazda Salesman!
1. Pretty sure the air pump starts before the engine to force air into the cat for better emissions on startup.... anyone verify this?
2. Gaps good on the new sparkplugs?
Old Feb 3, 2010 | 12:26 AM
hi maz!in all othes cars the air pump starts immediatly after you fire up the engine,in this one air pump starts when you put ignition on,without starting.
Old Feb 3, 2010 | 10:22 AM
Don't worry its for emissions only.
You need a new battery or to clean the connections and re-charge it.
Old Feb 4, 2010 | 12:19 AM
thnnks for the reply razz,but as i mentioned in the first post,ve have changed the battery,coils,sparks,and wires to eliminate this problem,but car still has a junky cold-start!
Old Feb 4, 2010 | 12:30 AM
Jon316G's Avatar
Grasshopper
If you have an '04 or '05, look into buying the upgraded starter if you don't have one already.
Does this sound familiar:
http://www.vimeo.com/3653485
Also, the air pump will not run if the vehicle/cat is already warm.
Old Feb 4, 2010 | 12:51 AM
What's the cranking AMPS ? CCA ?
Battery was updated to a larger size.
Still check the connections and look for a short due to corrision between the poles.
Old Feb 4, 2010 | 12:55 AM
Eddie54's Avatar
do you guys have a pic of the new starter? i bought my car used, and the previous owner doesn't know if the starter has been upgraded....on starts, it doesn't take too long, maybe a 2-3 seconds, but not as fast as the new starter in that video, lol
Old Feb 4, 2010 | 01:24 AM
Jon316G's Avatar
Grasshopper
Here is a DIY for swapping the starter:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-starter-change-swap-dummies-189410/
He mentions what to look for to see if you have the upgraded starter or not.
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
Jul 9, 2016 07:35 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
