Compression test numbers and math
Old Jan 31, 2010 | 01:00 PM
@!!narotordo's Avatar
FLAME ON!
Question Compression test numbers and math
Hi guys I tryed searching compression test threads and could not find what I'm looking for
I need to know how to do the math with my compression test numbers?
Or is there something for me to down load that I can plug my numbers into for a end result?
I have a felling I need a rebuild and if thats the case this mt did not last any longer than my at did
Old Jan 31, 2010 | 01:10 PM
oilrag22's Avatar
Have a go with this link:
http://foxed.ca/foxed/index.php?page=rotarycalc
Let me know what you came up with plz.
Grtz
Old Jan 31, 2010 | 01:12 PM
czar's Avatar
Almost boosted
nice thats the tool i have to measure the compression
Old Jan 31, 2010 | 01:30 PM
FLAME ON!
Thanks! I download that and run my numbers and post them up when I get home.
Old Jan 31, 2010 | 02:47 PM
Jon316G's Avatar
Grasshopper
@!!narotordo PMed me his numbers and using the calculator this is what I got:
Original numbers:
F
060 057 059 @ 184 RPM
R
065 069 071 @ 191 RPM
Using the calculator (rounded):
F
82 79 81
R
85 89 91
Mazda's specs are:
Standard = 120psi @ 250rpm
Minimum = 98.6psi @ 250rpm
I know the calculator is useful for corrections, but wouldn't the numbers change if he was turning the engine quicker (closer to 250rpm).
I'm obviously no expert on compression testing
Old Jan 31, 2010 | 04:13 PM
oilrag22's Avatar
Mazda had the specs up @ 250rpm, probably because that is the rev/min it should hit during the test. Of course numbers could better a bit by having a bit more rpm, having a slightly better seal and less pumping loss.
But these numbers are down by quite a bit, roughly corrected even down bout 40% from "healthy". The 50 rpm short will def. not make up for this percentage.
Don't know the mileage and way of use, but seems to me before all else fails or pops up as a "diagnostic problem" i would personally opt to make the engine healthy again, so basically a rebuild, def. new seals etc..
Old Jan 31, 2010 | 06:13 PM
someone's engine is toast...
Old Jan 31, 2010 | 06:22 PM
AJ's Shinka's Avatar
Enthusiast
Let's get some Iannetti seals and rebuild it.
Old Jan 31, 2010 | 07:21 PM
FLAME ON!
^Baller!
Yeah George its gone
Old Jan 31, 2010 | 08:10 PM
Nemesis8's Avatar
Bigus Rotus
Yep - looks like mine:
Old Jan 31, 2010 | 08:39 PM
FLAME ON!
^Dude! where did you get that cool looking chart? and how do you read that?
Old Feb 1, 2010 | 02:24 AM
Enthusiast
how about these numbers...(not mine)
26 21 24
191 rpm
Old Feb 1, 2010 | 03:10 AM
Easy_E1's Avatar
Gil, didn't you use the "Godfathers" compression tester?
Old Feb 1, 2010 | 11:04 AM
FLAME ON!
^Yes
Old Feb 1, 2010 | 12:47 PM
did you then multiply by 1.039 and adjust for cranking speed?
Old Feb 1, 2010 | 04:45 PM
Enthusiast
How do you adjust for cranking speed? Gracias Jorge. Iknowyournotmexican.
Old Feb 1, 2010 | 05:17 PM
here ya go AJ http://virusakos.freevar.com/
whosaidIwasmexican?
Old Feb 1, 2010 | 11:55 PM
Nemesis8's Avatar
Bigus Rotus
The word "compression"comes from an old Greek word I assume...
Gotta luv those those guys!
Old Feb 2, 2010 | 01:18 AM
volcomx31's Avatar
Silver Power
rotor #1: 7.5, 7.2, 7.4 at 239 RPM and rotor #2: 7.5, 8.0, 7.7 at 238 RPM
this is what i got from Tustin Mazda when i got my car back..are these good numbers for a compression test?
Old Feb 2, 2010 | 01:44 AM
Those numbers are pretty decent if you ask me ...
Old Feb 2, 2010 | 01:45 AM
SHHHHH ...
thats what im planning to do ... jesus how dare u ! u just told everybody !
Now I have to kill whoever knows my plan ... damn quite a lot of people to "finish" ...
Old Feb 2, 2010 | 02:09 AM
Just stuff them with that big cheesburger!
Old Feb 2, 2010 | 02:16 AM
volcomx31's Avatar
Silver Power
decent as in my engine is in good shape?
Old Feb 2, 2010 | 08:41 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Three someone's engines are toast...........The dealer will be busy today. Jedi, thanks to you and the others for coming on and giving the advise that you did. To be honest I forgot about the RPM correction.
Old Feb 2, 2010 | 10:11 AM
Enthusiast
whosaidIwasmexican?
No one, but gracia jorge so hispanic. lol gracias again.
