ANY ONE can help me flooded engine
Old Jan 27, 2010 | 12:25 PM
vinson_rx8's Avatar
CA ANY ONE can help me flooded engine
i was driving my car in the rain and go though in water right after it turned the engine off . i tow to the shop they said ( the engine it looked up ) so they need i have to get new or use engine pl help guys thanks
Old Jan 27, 2010 | 12:29 PM
jmc23200's Avatar
You cannot hydro lock a rotary engine. I bet this so called "Shop" has no idea what a rotary engine is.
Old Jan 27, 2010 | 12:32 PM
KrumbZ's Avatar
1.3L of Fury
sucks, next time put a lift kit on it...JK
Old Jan 27, 2010 | 12:34 PM
jmc23200's Avatar
Bring it to a Mazda Dealer. Don't mention the water. If they are as "brilliant" as the shop you brought it to, you will get a new engine under warranty.
Old Jan 27, 2010 | 12:35 PM
Brettus's Avatar
Boosted Kiwi
step one :
get your car away from those thieves and find a garage that knows something about our cars .
Old Jan 27, 2010 | 12:36 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
^+1 tustin mazda was pretty good
Old Jan 27, 2010 | 12:39 PM
Gee... you posted this in two different threads. See my answer under the DIY thread.
I wonder how many other times I will see your same post... ? ? ?
Old Jan 27, 2010 | 12:49 PM
jmc23200's Avatar
****, he has 9 posts.... that means there are 7 more of these threads out there
Old Jan 27, 2010 | 12:50 PM
Gr8Bullet's Avatar
Mazurfer's Avatar
Surf Hard, Drive Hard
God, I hope not!
Old Jan 27, 2010 | 01:43 PM
vinson_rx8's Avatar
i need help plzz
vinson_rx8's Avatar
i bought it use so no underwaranty
Old Jan 27, 2010 | 01:44 PM
Gr8Bullet's Avatar
use the search function...
Old Jan 27, 2010 | 01:54 PM
Brettus's Avatar
Boosted Kiwi
dry out the air filter
clean and dry out the maf
disconnect the fuel injection and spark fues then remove the leading spark plugs and turn over the engine for a minimum of 30seconds .
Reassemble and start normally
If that does not work and it is not an auto - tow start it ......
read this thread for how to do it
https://www.rx8club.com/rx-8-discussion-3/thanks-rotarygod-how-resurrect-your-flooded-rx8-ten-minutes-less-188752/
Old Jan 27, 2010 | 02:03 PM
vinson_rx8's Avatar
i tried hight air presser and tow but it didnt work any idea
Old Jan 27, 2010 | 02:04 PM
kersh4w's Avatar
Hit & Run Magnet
what bret said.
push the car or roll it down a hill if there is one close by.
let the clutch out in 2nd gear while cranking the car.
the car will start magically.
Brettus's Avatar
Boosted Kiwi
wat - speak english !
Old Jan 27, 2010 | 02:08 PM
vinson_rx8's Avatar
yeah but not much , wat they said it the engine was hydro
Old Jan 27, 2010 | 02:10 PM
kersh4w's Avatar
Hit & Run Magnet
YOU CANNOT HYDROLOCK A ROTARY ENGINE.
It is IMPOSSIBLE.
Also, it was already stated in this thread.
TELL THE SHOP YOU NEED TO TOW START THE CAR.
Old Jan 27, 2010 | 02:12 PM
Brettus's Avatar
Boosted Kiwi
well I gave you a proceedure on how to fix that . What else do you need to know ?
Old Jan 27, 2010 | 02:16 PM
He needs a Video!
Old Jan 27, 2010 | 02:21 PM
greg985's Avatar
The 337
you are a fuvkin retard
Mazurfer's Avatar
It is IMPOSSIBLE.
Technically.......we don't know it's a manual yet. He hasn't said in either thread. Nor do we know his location.......not that it matters, but if we knew, we might be able to point him in the right direction!
Old Jan 27, 2010 | 02:22 PM
vinson_rx8's Avatar
it didnt crank
Old Jan 27, 2010 | 02:23 PM
vinson_rx8's Avatar
i live in ORANGE COUNTRY ,CA 92703
MY IT MT
