Which rotor is more prone to failure? Front or Rear?
Old Jan 24, 2010 | 12:51 AM
Mawnee's Avatar
I divide by zero
Going to install my injectors today. One flows slightly more than the other so I figure I'll put the higher flowing one on the "more fragile" rotor. Its not much, but hey...every little bit helps
Old Jan 24, 2010 | 12:53 AM
05rex8's Avatar
sold the 8... :(
rear
injector is not the problem.
IMO, the path of the coolant flows is (which cannot be resolved ...)
Old Jan 24, 2010 | 01:02 AM
Mawnee's Avatar
I divide by zero
I'm not trying to use this as a cure all.... This is a buffer should I go a tad lean when I turn up the boost.
Its an old LS1 trick, I did the same on my vette. On those the #7 cylinder runs just slightly leaner due to the intake design. If you got bad enough detonation to fry a piston, it would almost always be the #7. So we would put our highest flowing injector there to give a little more breathing room incase you lean out.
It may not make a bit of difference on our engines...but it couldnt hurt either
Panthersn
Jul 13, 2021 06:30 AM
Billy Marcial
Mar 1, 2018 06:50 AM
jlm2664
SE For Sale/Wanted
Mar 9, 2016 11:50 AM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
