'09 R3 question,, noise ?
Old Jan 19, 2010 | 08:34 PM
mjones53's Avatar
Bought it new a couple weeks ago, it seems to have a weird roar or hum in the rear end at about 70mph, is that normal. Can't pin point what it might be.
Old Jan 19, 2010 | 09:56 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Have someone else verify, maybe even record it.
Old Jan 19, 2010 | 10:09 PM
Pico's Avatar
It's Complicated
Depending on your location it take a little time for the rear diff. to get to temp which can cause a hum or vibration-- this stops after a few miles
In cold temps tire can develop flat spots from sitting in the cold conditions over night-- this also stops after tire temps rise.
It also could be a balance issue. does its sound different at high speeds then slower?
If this isn't the problem then I would check your lugs
More info would help your cause. When does it happen and how long??
Old Jan 19, 2010 | 11:35 PM
ultrataco's Avatar
I haven't noticed it in mine. I'll listen next time I drive it. How many miles does it have?
Old Jan 20, 2010 | 05:20 AM
mjones53's Avatar
just turned 1100 miles, nothing is shaking it rides very smooth, not like a tire balance issue. Sounds like it coming from the rear end. I'll try and go by the dealer but, i'm sure they will say its normal. But, it's not
RevMeHarder
Jun 1, 2026 02:30 PM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
yankeepicker
Sep 11, 2015 05:42 PM
