Planning on buying a 2005 RX-8. Is it worth?
Old Jan 17, 2010 | 11:00 AM
VRUUUM's Avatar
Question Planning on buying a 2005 RX-8. Is it worth?
I want to buy a used RX-8, 2005.
What should I look for in terms of possible defects and recalls?
Is it worth buying a used one, or should I go for another car to save me from headaches?
Old Jan 17, 2010 | 11:09 AM
robrecht's Avatar
I typically buy used cars, but I look for very low mileage, like under 10k. IIRC, the most important flash was in August 2006. If an RX-8 had a lot of miles put on it before that flash, you might want to consider a compression/vacuum test, but that's not as simple of a test as on a piston engine.
Old Jan 17, 2010 | 11:10 AM
Krazed_Rx8's Avatar
Save us all the headache and use the search function in this forum...
Get the VIN of the car and call Mazda, they'll be able to tell you if recalls have been done. Do your own research to find out if its worth it.
Old Jan 17, 2010 | 11:18 AM
robrecht's Avatar
Mazda Customer Support at 1-800-222-5500 can give you this information on any car.
Old Jan 17, 2010 | 12:58 PM
Take a Auto shop class. you need to add oil to keep the Apex seal lubed.
Old Jan 17, 2010 | 07:19 PM
volcomx31's Avatar
Silver Power
save yourself
Old Jan 18, 2010 | 10:51 AM
Loki's Avatar
Define "worth it".. these cars lose value quickly, so you could score one with low miles for half the price of new.
As far as what to look for, firstly take a good hard look at the previous owner. See if he knows to keep an eye on the oil level, do his fluid changes religiously, warm it up completely (not just until the temp gauge gets to middle), not turn it off when cold, knows not to flood it, drive it hard (this is a good thing.. if these engines are babied they tend to get bored and die), and is generally a rotary enthusiast, then you probably have a good lead.
As far as the car, aside from verifying the recalls have been done, see when the coilpacks and spark plugs were last changed (much above 30k?), check the clutch pedal for creaking and excessive side play (the bracket is known to fail), check the coolant reservoir for leaks and cracks and check for rust at the door sill where the suicide doors close. Oh, and ask if the headlight auto-leveling error light has ever come on while driving, there is a TSB about this.
Old Jan 18, 2010 | 11:06 AM
MICHGoBlue's Avatar
since this is the first thread I've ever seen asking this kind of question, I'm going to have to say get another car.
Old Jan 18, 2010 | 11:14 AM
Huey52's Avatar
Registered Zoom Zoomer
My 2005 (bought new March '06) has about 25k miles on it now and runs like a champ. Of course I've kept up on all TSBs/recalls, change the oil every 3k miles, pre-mix, over maintain 'plugs/coils/cables/filters, etc.
Make sure you get a good owner service history and combined with the Mazda VIN insight you should be fine. 2005's are significantly devalued now so a real steal (my Shinka is probably only worth ~$12K these days).
Aside from checking the oil level a little more often (apex seal lubrication) they really don't require any more service than any other vehicle, but again timely and regular service is the key.
Old Jan 18, 2010 | 06:18 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Buy a Civic.
Old Jan 18, 2010 | 06:30 PM
valpac's Avatar
Ahead of its time
its worth it to me. Had my 05 (and owned other rotaries) since new and never tire of it. Sounds like you have alot of research yet to do.
Old Jan 18, 2010 | 07:45 PM
05TouringRX8's Avatar
We love our 05. Had superb history, all TSB's done, low miles and looked like it had never even seen a raindrop when I bought it. Also passed the VINCheck (CARFAX) with flying colors.
Old Jan 18, 2010 | 07:58 PM
SayNoToPistons's Avatar
Wheels, not rims!!
If you have to post a thread and ask that question now. Don't buy an RX8.
Old Jan 18, 2010 | 09:17 PM
^ Agree.
ASH8
20
Sep 26, 2022 11:55 PM
projectr13b
Mar 1, 2019 09:00 AM
CarAndDriver
Sep 25, 2015 01:18 PM
Lee_1420
Aug 10, 2015 01:05 PM
nnsoch1776
Jul 22, 2015 04:16 PM
