Check engine light. Rear 02 sensor
Old Jan 14, 2010 | 10:56 PM
marshallchang's Avatar
Legit
Hey, so i recently put in an RP midpipe on my rx8, and unfortunately i stripped the hell out of the oem o2 sensor... Regardless we threw it on the RP midpipe and it fell out on a drive somewhere. Up to this point the check engine light was not going on, until it fell off. So i just put in a new OEM o2 sensor, but the check engine light is still on. Is there something i need to reset?
Old Jan 14, 2010 | 11:02 PM
Cat less mid pipe? If it is then you wasted money on a new rear O2 because you will get a CEL regardless unless you have a COBB AP. If you do have a cat there are numerous threads on resetting the ECU.
Old Jan 14, 2010 | 11:55 PM
Legit
It's catless, and I assumed that the check engine light would turn on, but i drove it for 2 or 3 days without the check engine light coming on - before the sensor came off, and only after the sensor came off did the check engine light come back on.
Old Jan 15, 2010 | 12:51 AM
Legit
Reset
If i brought it to a shop would they be able to reset the computer so that it'd stop showing the check engine light?
vapor2
Nov 3, 2020 03:38 PM
RXeckless
Aug 16, 2015 12:52 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
