View Full Version : Exhaust Air Intake - has anyone tried this?
edmonton
01-13-2010, 12:48 PM
I was at the dealership a while ago and noticed they had an Exhaust Air Intake available for about $600 or so. I was wondering if anyone has tried this out and if it actually makes much of a difference. I have a 2009 R-3 I'd like to put it on, but if you can't really tell the difference, it would be pointless. The dealer couldn't even give me much info about added HP, etc. Any info would help! Thanks!:)
mike[piston eater]
01-13-2010, 01:05 PM
no intake will add significant horsepower, but the best ones are the ms/aem or the racingbeat w/ duct
9krpmrx8
01-13-2010, 01:06 PM
Exhaust Air Intake?
:ftw:
mike[piston eater]
01-13-2010, 01:08 PM
same question i had
schnipster
01-14-2010, 10:02 AM
zero power...fact....its like putting runners on a fat chick...she will not run any faster
schnipster
01-14-2010, 10:03 AM
cool sucking sound....mentally will give you horsepower......for 600 bucks you will have to handwash your car as if it gets wet.....aaah
alnielsen
01-14-2010, 10:36 AM
Recirculating the exhaust would kill the engine. You must be mistaken. The car already comes with a cold air intake.
There was once a warm air intake for carburetor engines. Air was funneled past the exhaust manifold into the carb in cold weather. A vacuum operated thermostat would close this off when the temperature raised to a certain point. This isn't necessary any more due to MAF/MAS sensors and ECM controlled fuel injection.
Snrub
01-14-2010, 12:48 PM
Ever heard of an EGR? ;) (I recognize this is different from the issue you're addressing)
edmonton
01-15-2010, 10:19 AM
No I haven't heard of an EGR? How does it work?
Jon316G
01-15-2010, 10:21 AM
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
alnielsen
01-15-2010, 10:37 AM
Yea, I forgot about that. I always disabled it.
edmonton
01-16-2010, 11:01 AM
Thanks for the info. Is it tough to disable it? Have you found a noticeable difference with it disabled?
