Check Engine Light
Old Jan 9, 2010 | 07:10 PM
Chelsea11's Avatar
Check Engine Light
I was driving my RX8 and my check engine light came on. I had been driving it for about 15-20minutes before this happened. My oil pressure and temperature were at normal levels and my car was running normally. I took it to auto zone to see what was wrong and they said that it coded that the target AF feedback system was too lean- right bank. It said that the probable causes could be 1) large vacuum leak, 2) fuel system malfunction, 3) MAF sensor faulty, or 4) ignition system malfunction. My car continues to run fine and all gauges are at their normal levels. We have had much colder weather here than normal. When my light came on the temperature had dropped to 20. Could the temperature be causing my sensors to malfunction? Is this a normal thing? Any info will help. Thanks for any help!
Old Jan 9, 2010 | 08:04 PM
shaunv74's Avatar
Power!!
Here is a related thread with the exact same problem.
https://www.rx8club.com/showthread.p...ighlight=P2096
The simplest and most likely cause is a dirty MAF sensor or intake Air temp. sensor. These can be easily cleaned. Details on how to do this are in the linked thread. I would post further questions in that related thread so others will see your question.
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
