Steering motor frozen?
Old Jan 8, 2010 | 01:32 PM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
TX Steering motor frozen?
Got up this morning got to the car to crank it up and let it warm up a bit. AMB read 18 on the display went to go turn the wheel and it was stuck. Like on major lock wouldn't move a cm. I'm sitting there like WTf is going on? My electrical power steering motor was frozen I assume. Had to sit in the car with it running for about 15 minutes before the steering was released to where I could turn the wheel then it was fine driving after that. I live in dallas so first of all 18 degrees really?!? and second, is anyone else having this issue?
Old Jan 8, 2010 | 01:45 PM
Glitched's Avatar
Was around 8 degs here last night when I left work... I didn't have any issues
Old Jan 8, 2010 | 02:00 PM
JTtheDude's Avatar
Never had that problem but mine has been sitting outside in these low temps for several days straight, I'm going to start it up when I get off work today and see how it behaves. Dallas area is seeing coldest temps in past 13yrs or something like that.
Old Jan 8, 2010 | 02:23 PM
Lord ET's Avatar
Is that a bike rack?
My garage never really lets it get below 40F
Old Jan 8, 2010 | 03:43 PM
Turbo SR20deT Son!
Well this sucks.
Old Jan 8, 2010 | 03:46 PM
rodjonathan's Avatar
silent assasin
i had that problem too it got cold here last night but its in the garage now ima drive my dads car till we get back above freezing
Old Jan 8, 2010 | 06:13 PM
1.3L's Avatar
I've been able to turn my steering wheel with the engine and electrical system off, but it does take quite a bit of effort.
-1.3L
Old Jan 8, 2010 | 06:26 PM
cyclone1208's Avatar
the only problem i have with the cold weather is starting it up.....i just put a new battery and the cranks are alot longer than usual
Old Jan 8, 2010 | 06:43 PM
invasion08's Avatar
Was the Power Steering Malfunction Indicator Light on during this? Note: The steering may feel rigid if you continuously attempt to steer when the vehicle is stopped or moving extremely slowly. This has been designed to protect the system and does not indicate a malfunction. If you do not attempt to steer for a minute power steering will be restored.
Old Jan 8, 2010 | 06:46 PM
CyberPitz's Avatar
Huge hole is huge
Starting in -10 degrees and it was A-OK.
Old Jan 8, 2010 | 06:48 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Waits for noob to ask if it could potentially be the fluid that's frozen?????
Old Jan 8, 2010 | 06:51 PM
CyberPitz's Avatar
Huge hole is huge
Well? If the fluid was frozen wouldn't that stop the wheel from moving?!?!?!?!
j/k
Old Jan 8, 2010 | 07:48 PM
05rx8gt's Avatar
Yes happen to me last nite leaving a party but only lasted a sec so didn't think about it.. I live in Austin and car is never park outside unless i go some where
Old Jan 11, 2010 | 10:25 AM
Turbo SR20deT Son!
No I had that issue before where it malfuntioned and this one is a replacement cause the original failed when I was driving and that wasn't a pretty scene. In this instance it wouldnt release the steering until the motor was defrosted. First few times it released when the car warmed up but when we hit under 20 its took about 10 extra minutes before it released the steering.
Old Jan 11, 2010 | 02:23 PM
Most cars will lock the steering wheel if turned all the way to the right or left.
You just have to jerk it a little to unlock it.
Saftey feature.
bosstin87
Oct 5, 2015 06:52 AM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
