CarPC with stock Nav
Old Jan 5, 2010 | 10:42 AM
ninjajim4's Avatar
hey gang.. just picked up an 05 ti grey rx-8 a few weeks ago, came with the full GT package, MS front and rear spoiler. still have the rear and side skirts to go. in the meantime, i decided to get going on the interior, adding a USB touchscreen overlay to the stock nav screen, wired up the avelectronics av switcher, and installed Car2PC on the radio's aux port. pulled up the center console to run everything to the trunk.
i am waiting on a 3.5mm extension cable to run from front to back before i can button everything up.
touch screen overlay:
touchscreen installed:
all back together (or before?? not sure.. ):
going back into the dash:
the CarPC:
the RX! :
to be continued...
Old Feb 16, 2010 | 09:21 PM
ninjajim4's Avatar
little update... touchscreen overlay fully installed, works like a charm. avswitcher installed, toggles between oem nav and carpc, with autoswitch reverse camera.
here's some screenshots of the carpc -- nothing else to show because everything looks 100% oem:
CarPC home screen:
toggle back to OEM nav:
music videos:
integrated handsfree bluetooth:
weather:
will update later with some shots of reverse camera, OBDII readings if anyone is interested.
also hardwired in the radar detector (bel sti driver), with cheetah mirror, smart cord placed in the dash panel blank next to the dimmer switch
Old Feb 16, 2010 | 11:39 PM
ARE-EX-8's Avatar
Rotary > Piston
thats sick... good job. Where did u mount the camera ??
Old Feb 17, 2010 | 08:51 AM
ninjajim4's Avatar
thanks man... camera is just mounted with double sided tape on the underside of the license plate cutout, ie next to the license plate light. will take a pic for you. not sure if i'm happy about the location, as it's not as stealth as i'd have liked -- but then there's not a lot of options either...
Old Feb 17, 2010 | 11:54 AM
danysrx8's Avatar
dude where did you get the car pc from and the touch screen overlay from.............man i wish i could do all that
Old Feb 17, 2010 | 04:49 PM
Spiritus Sancti's Avatar
very nice ... nicely done. Good job!
Old Feb 17, 2010 | 04:52 PM
Lord ET's Avatar
Is that a bike rack?
I believe there's a DIY for installing the camera in the trunk keyhole.
Old Feb 18, 2010 | 08:50 AM
ninjajim4's Avatar
carPC i bought barebones from mo-co-so.com since i had some extra parts lying around, so i saved a little bit. i would have bought everything from scratch but it was cheaper to get the package. basically the only thing specific to a car application is the power supply, which has a controller that turns the PC on and off with the car's ignition. i used a mini itx board for its small form factor.
this was actually in my MX-3 before, so i didn't spend any new money really -- plus someone broke in and took my monitor from the MX, which I didn't care about anyway, since I planned on bringing this setup into the RX anyway, and would have no use for a monitor in the MX anymore. anyway it was a POS and the audio processing was horrible.
touchscreen overlay was REALLY cheap.
http://cgi.ebay.com/For-Asus-EEE-PC-...item2ea8e9891f
i don't know why more people don't go this route or talk about it, but i just took a chance on it and it works beautifully. no one realizes i added it in.
most expensive thing was the av switcher, which i was pissed about. for the same price i probably could have just bought a touch screen monitor with its own proper inputs instead. but i wanted to keep the oem nav since the lock times are soooo much quicker, and i didn't see any info out there about using the nav video on a different monitor. and it has reverse camera function built in. i was worried that the composite quality would suck compared to VGA, but it's definitely fine, as you can see from the pics (though not AS good).
in the end i'm very glad i picked a car with nav since i look around and the oem nav housing is very expensive after the fact, along with the cost of a monitor would be like 6-700 bucks. so i figure i saved money in the end.
Old Feb 21, 2010 | 03:25 PM
JessiahC's Avatar
Nitrous Threadjacker
This is exactly what I've been looking for for the past year!! I have been contemplating about how to go about it myself. What software are you running the the carPC for all those features that you have?
Also, what model of kit did you get from mo-co-so.com? I'm looking for the one that you have that has the composite output or did you just use a S-video to composite adaptor?
Old Feb 21, 2010 | 07:22 PM
hakuna matata!
software is centrafuse
Old Feb 21, 2010 | 07:50 PM
NErx8's Avatar
There is indeed a DIY for the key hole camera mount. Looked pretty cool and blended in nicely : ) Not sure where it was on the site but I came across it not too long ago.
Old Feb 21, 2010 | 08:26 PM
JessiahC's Avatar
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-trunk-keyhole-camera-installed-62547/
Old Feb 21, 2010 | 09:05 PM
myriadshalaks's Avatar
rot8ing
that looks great, man.
is the bluetooth an extra component, or does it come with the carpc?
would love a diy.
Old Feb 22, 2010 | 02:37 AM
JessiahC's Avatar
would love a diy.
Most of them do have integrated Bluetooth as part of the bare bones kit, but external USB Bluetooth dongles are rather inexpensive to purchase nowadays. As soon as I get back to the states I'll be doing mine, or if I'm feeling impatient I'll have someone do it for me, lol.
Edit:
Due to the electromagnetic interference in an environment such as a CarPC you may want to consider a bluetooth adaptor with an external antenna to maintain proper connection with devices in the front of the car. That is implying that you're planning on stationing the actual PC module in the trunk or somewhere in the rear of the vehicle.
Old Feb 22, 2010 | 10:27 AM
ninjajim4's Avatar
so far as i know, there's no such thing as bluetooth that comes integrated on the motherboard per se, the way sound and video are. even laptops have an add on module. mine was included in the package and advertised as 'internal', but in reality there is just a USB port inside the case with a bluetooth dongle attached to it.
i have since pulled that, and put it on the end of a usb extension, along the lines of what JC was saying. obviously you will need a microphone of some kind, but that's it, no other costs involved. i bought an andrea superbeam mic for 40 bucks, which is supposed to cut down on echo quite a bit. haven't played around with it too much to say if i really like this solution
Old Feb 22, 2010 | 01:59 PM
JessiahC's Avatar
LOL, now that's just classy.
USB Extension cables have saved my *** more times than I care to count. As an alternative to getting a bluetooth antenna, running a dongle on the end of usb exension wouldn't be a bad idea at all, especially if you hook it up to a USB hub up front, say if you were going to be running a USB OBDII Port access or something like that. You could also use that to put a USB camera under your front bumper.
Old Feb 25, 2010 | 11:46 AM
ninjajim4's Avatar
forgot to answer this one.. but it is a VIA Jetway board. it actually has both s-video and composite outputs, which was seriously ridiculous to setup, but ended up being very handy. i actually hooked up both to a 19" LCD tv to see if I could see a difference in quality, and it's really negligible (obviously comparing either to VGA is a different story). i wouldn't pay the extra expense just have s-video.
Old Mar 21, 2010 | 02:03 PM
hakuna matata!
good stuff, as i mentioned in the other thread though, the resolution would really bother me.
but i guess using centrafuse as a front end you don't have to worry much about it since it's purpose built.
Old Apr 1, 2010 | 01:47 AM
mmctsai's Avatar
Hi ninjajim4, thanks for sharing your revolutionary mods. This is exciting to see your thread because I would like to modify my newly sourced OEM nav to touch screen and install on my non nav MY2007. The challenge is.... I am not much a tech savvy and I do not prefer car pc option. Is it possible to link the touch screen panel to dvd player or what ever player and aux in OEM head unit? and other suggestion or alternatives? Thanks mate.
Old Apr 1, 2010 | 10:36 AM
ninjajim4's Avatar
i think you'd be surprised if you saw it in person. obviously working within windows over composite is no treat, but like you said, within centrafuse it's a different story. everything is nice and crisp
lol thanks but nothing i did is exactly revolutionary. if it's not clear, i do NOT have touch capabilities for my OEM nav, it only works for the carPC. i hear some people have been able to accomplish this (on other cars), though i haven't really looked into it.
so that's not really going to work for a dvd player, because you need to have some way to input the touchscreen into it, which your standard dvd player will not have. sorry to disappoint. my only advice for what you want without too much effort would be to swap out the head unit with an touchscreen nav/dvd unit
Old Apr 2, 2010 | 07:52 PM
mmctsai's Avatar
alrght man, thanks alot mate
Old Apr 3, 2010 | 11:13 AM
AhadV's Avatar
very impressive. Looks awesome
Old Apr 6, 2010 | 09:27 PM
mmctsai's Avatar
Hi, sorry I have searched the forum and got tons of info which really confusses me since I am not a tech savy.... I am about to purchase 000-NVI-D1 from AV Electric, pls see link below
http://www.mazdaparts.com/ProductDet...000-1151625270
my problem is, I do not have the OEM wiring harness and I have found electic diagram but I do not know how to link 000-NVI-D1 to OEM screen? how do i wire? pls see diagram I am refering too below,
https://www.rx8club.com/showthread.p...hlight=OEM+Nav
Please assist, thanks alot!
Ps: Can I use this instead of normal AV switcher below istead of 000-NVI-D1?
http://cgi.ebay.com.sg/4-group-AV-Au...item414ab9006a
Old Apr 7, 2010 | 08:14 AM
ninjajim4's Avatar
do you have the stock nav? if so, how do you have it, but not have the oem wiring? if you don't, then i wouldn't bother to go this route at all. just do what alz0rz did and get a good touch panel monitor with reverse camera built in, no need for the avswitcher at all.
what i did is ONLY to retain and enhance what already came with the car. if you're starting from scratch, there's a lot more options
Old Apr 7, 2010 | 11:47 PM
mmctsai's Avatar
Thanks ninjajim, my car is non NAV and i have purchased the OEM motorised Nav screen from one of the forum member. Therefore I am trying to figure out how to link the screen to DVD player and reverse cam. how do you link your avswitcher to the screen? with the existing wiring harness? Thanks
