white smokey exahust
Old Jan 1, 2010 | 04:19 PM
guillermo6545's Avatar
my rx8 has flooded like is common with the rx8, the thing is that when i did get it started, i noticed alot of white exahust and when i got out and went to the rear of the car, it smells srtange.
if anyone has had this problem, or knows what the problem might be
i would appriciate any advice
Old Jan 1, 2010 | 04:22 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
If flooded, then you will get a lot of smoke when you first get it cranked up. Not an issue.
Now on the other hand, if this happens after a few good runs, then you need to let some smoke get on your hands and then smell it and see if it smells sweet.
BTW........how do you keep flooding it? I've just crossed four years and have never flooded.
I assume you have no CEL lit up?
Old Jan 3, 2010 | 01:31 AM
Sparks91188's Avatar
The elusive one
I have the same thing going on with my 04 and it does smell sweet plus I have a CEL. my poor girl has been eating gas worse than normal getting really bad gas mileage also she struggles pas 4 rpms and shakes and seems to misfire. i plan on taking her in to the shop though I would rather avoid it.
Old Jan 6, 2010 | 02:37 PM
ODDDOOD's Avatar
The DOOD abides.
guillermo - hmmm...I know white smoke normally means antifreeze is burning, but I read earlier today about white smoke and a potentially failing catalytic converter.
Since you just flooded your car and dumped gasoline to the exhaust, I predict that your catalytic converter will fail soon. Been there done that.
Try removing the cat for inspection.
Sparks - get your CEL code read ASAP. Search the code number on the forum and will likely lead you to the right place.
Cheers
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
UnrealOne
Sep 30, 2015 11:04 AM
Rx8_412
Sep 24, 2015 08:51 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
