Car suddenly runs like crap after Dealership Reflash
Old Jan 1, 2010 | 02:51 AM
iLikeEatPoo's Avatar
The Great Dick
So I lost my key so I took my car to the dealership to get a new key programs and also asked them if there was any available recalls or warranties on my car I didn't know about and they said there was a ECU recall and I had a free reflash as well as a new motor up to 100k miles.
So I had the key made and ECU reflashed. Car ran fine until I hit the freeway. Sudden bogging at 4.5k and 8k rpm and my Air fuel ratio gauge was telling me I'm leaning out like crazy. I never hit ideal or rich even for a second. First I think Okay 4.5k most likely the cat. But I kept thinking why is my AFR gauge reading lean so badly? Before when I'm cruising it's a little bit rich and when I stomp it's perfectly dead center ideal and would only go a little lean when I throw it into neutral or let off the gas suddenly. My CEL is also stuck on. My car is pretty much stock. Intake exhaust grounding kit coilovers. Nothing that would throw off a CEL.
Anyone else have this problem? I'm about to call the dealership tmmr to see what is up.
Old Jan 1, 2010 | 03:19 AM
Flashwing's Avatar
3-wheeler
What kind of intake?
Old Jan 1, 2010 | 05:44 AM
The Great Dick
custom cold air. but I had it for over 6 months already I don't think it would act up now. All the stock lines are still on the accordion tube. VFlad has been removed.
Old Jan 1, 2010 | 06:16 AM
rotarykillz's Avatar
Rotary Freak
I thought this behavior was expected for the first hundred miles driven on the car after a PCM flash.
Old Jan 1, 2010 | 07:26 AM
DeViLbOi's Avatar
The devil made me do it
I bet you that while they worked on your car they bumped something and you just have a vacuum leak under there somewhere.
Old Jan 1, 2010 | 07:28 AM
Jon316G's Avatar
Grasshopper
Knowing what the CEL code is will help much.
Old Jan 1, 2010 | 07:52 AM
rxat2012's Avatar
it is you intake...... when they reflashed the pcm it erased all that data the pcm likes to keep..... drive it around a few times it should sort itself out or you need to check the design of you intake.... pipe size, screens, and what not..... what your saying sounds similar to what happened mine.... and that is what fixed it for me.... dont know if it will help but check it out.... oh and if it is what im thinking it is the cel will be maf related
Old Jan 1, 2010 | 12:29 PM
The Great Dick
I'm going to get the CEL code checked today hopefully if I can find a place that will check it for free. If not I'm going to call the dealership and ask them what is going on. Also my vacuum gauge is reading a steady 21 PSI like it always did before the reflash so I don't think it's a vac leak. But I'll check anyway.
Old Jan 1, 2010 | 01:51 PM
Flashwing's Avatar
3-wheeler
If your VFAD is removed I would go back to your stock intake. Any "custom" applications are only going to cause problems with the mass airflow sensor which could be causing your driving issues.
The upper RPM stuff I'm not sure about but anything that's in closed loop will be effected by the fuel trims being reset with the flash.
Do you have screens in your intake? If not, that will cause problems.
If the tubing your using before the MAF is larger (most likely) it could cause lean problems in the upper RPM area.
Either way, the stock intake is perfectly fine and does not need replacement. It's got a huge filter surface area and flows all the air you need. It's not glamorous but it works.
Edit:
A vacuum leak is also possible and will cause overall lean conditions.
Old Jan 1, 2010 | 04:53 PM
The Great Dick
intake tubing is 3''
but either way wouldn't it have caused problems a long time ago.
Old Jan 1, 2010 | 05:45 PM
The Great Dick
Just reset the ECU and did the 20 brake tap. Still the same. CEL was off turned on after a few minutes.
Old Jan 1, 2010 | 06:14 PM
Flashwing's Avatar
3-wheeler
Depends, when was the last time your PCM was reset or battery had been pulled for a couple hours?
If you're getting a CEL however that points to a different issue. If it's a vaccum leak you might be getting a too lean CEL.
Either way, pulling the code would be the first step as it will narrow down the issue.
Old Jan 1, 2010 | 10:21 PM
The Great Dick
Since the intake my battery was pulled 3 or 4 times. for a few hours I'm ordering a OBD2 reader tmmr so I can find the exact codes. It might just be a dying cat..
9krpmrx8
Nov 5, 2015 11:45 PM
Quato_jr
Aug 4, 2015 09:22 AM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
tbiggybig
41
Jul 22, 2015 11:47 PM
