@!!narotordo
12-29-2009, 12:19 AM
Ok so my friends RX-8 backfires stalls then floods :suspect:
Car has good compression, coils, batterie, ect. Oh its a Shinka :D:
What can it be?!!!!!!!
9krpmrx8
12-29-2009, 12:36 AM
Firing order messed up? Disconnect battery?
@!!narotordo
12-29-2009, 05:58 AM
Will pressing the brake peddle till the oil gauge sweeps reset it? or do we have to disconnect the battery?
rotarykillz
12-29-2009, 06:27 AM
if your firing order is messed up its b/c the spark plug wires are on wrong. could be bad plugs too.
AJ's Shinka
12-30-2009, 06:59 PM
Okay both of you were correct but it wasn't the plug wires it was at the MS harness... firing order is correct now and it is still stalling out. We did the footstomp on the brake pedal but some say that is not good enough, but I will now disconnect the battery to see if this fixes it. It helped this guy.
http://www.rx8club.com/showthread.php?p=3370315&posted=1#post3370315
Thanks for the advice guys!
Rote8
12-30-2009, 07:46 PM
Pull ROOM fuse; bottom fuse of the inside fuse panel.
Then do the brake pedal "chicken dance".
Have the fuel injection wires ever been removed?
AJ's Shinka
12-30-2009, 10:57 PM
Thanks for the reply Rote8
I will pull the ROOM fuse as soon as I get her deflooded then I will do the the break chicken dance. I have done the chicken dance before but not the ROOM fuse.
I have not removed the fuel injector wires and I bought it from another guy that had the car completely stock. I removed the fuel pump because I thought it was going bad and swapped it out with a good one but it was not the problem.
AJ's Shinka
01-03-2010, 04:16 AM
I was goingto go back to stock coils and found some bad grounds on the ignition kit setup. Good grounds now and she is runnning flawlessly. Thanks everyone.
