View Poll Results: which tires to go with 18x8.5
245/40/18
100.00%
245/45/18
0%
235/40/18
0%
235/45/18
0%
other, please specify below
0%
Voters: 6. You may not vote on this poll
18x8.5 44os with 245/40/18???
Old Dec 26, 2009 | 02:15 AM
J wind's Avatar
Alright, so after all the searching, I think I'm actually more confused then when I started off lol.
The wheels I'll be getting are 18x8.5 with a 44mm offset, and weight 22.5lbs. And from what I can conclude is that I should be fine with this set up with no need to roll my fenders. The tires I'm considering are Yokohama advans s4 or S drives, in 245/40/18.
So how much will I be screwing with the the cars odo? I think from switching from 225 on my stockers, to 245 on the new rims, I'll be adding an extra 100 miles for every 1000 miles I drive right? What would be the most efficent size tire should I slap onto my 18x8.5? I don't want to stretch my tires hence why I decided on 245s.
Now if the 245s are stretching, would getting 245/45/18 help increase comfort? I read that 245/40 does cause a bit more oversteer when hairpins or tight cornering is met. So would the 45 sidewall help keep it stable because of the extra flex? I just want to keep it pretty neutral like the way it is now with my stockers.
I've no plans for tracking my 8 but do run alot of spirited driving. Its really more of a weekend grand tourer that tackles a few twisties for fun. But I might give auto x a try down the line.
Old Dec 26, 2009 | 02:54 AM
NgoRX8's Avatar
100 extra miles for every 1000 miles? LOL! that's excessive
going from 225/45/18 to 245/40/18 will add about half a mile to your tach for every 60 miles you drive. use this http://www.miata.net/garage/tirecalc.html
that tire setup is about as close as you can get to the stock tire diameter while using wider tires for our cars.
Old Dec 26, 2009 | 09:11 AM
J wind's Avatar
haha oops Alright I guess I'll give a +1 for the 245/45 then
Old Dec 26, 2009 | 09:58 AM
J8635621's Avatar
Pew Pew Pew
245/40 is what you mean. 245/45/18 would mess up your speedo more. 255/40/18 is the same diameter as stock, while 245/40 is within a percent or two.
Old Dec 27, 2009 | 10:20 AM
dezau's Avatar
245/40/18 there's a reason why lotta ppl choose this over 45
Old Dec 27, 2009 | 09:36 PM
J wind's Avatar
yea, looks like I've got my answer lol. Thanks again everybody.
OnebaddRx8
Oct 17, 2015 10:05 PM
GranTouTou
Sep 30, 2015 06:11 AM
ktec
Sep 19, 2015 08:58 PM
wayloco
Sep 1, 2015 09:03 PM
Kahl
Aug 20, 2015 11:49 PM
