Painting brake calipers
Old Dec 24, 2009 | 03:55 PM
djboyd's Avatar
Ok, I admit I am a novice at painting and pretty clueless, but I've been trying to do some research.
I do not feeling like removing the calipers to paint, and have decided to just remove the wheels. I think I'll use the G2 paint kit, but is there anything else I should know? This will be my first time painting anything on my car.
Do you just clean the brakes and apply the paint? I understand some people were talking about sanding first...
Also, is a clear coat necessary? I know it has to be heat resistant, and some people said they didnt use one, but what would be the benefits of applying 2 layers of this clear coat.
Thanks for the help, and if you have any other tips please let me know.
Old Dec 24, 2009 | 04:56 PM
josuar88's Avatar
The Crawlster
I used some sponge brushes and some spray paint to do mine. spray the spray paint on the brushes then apply you need a couple I'd say a brush per caliper they tend to break apart.
Old Dec 24, 2009 | 05:05 PM
expo1's Avatar
He's as bad as Can
I used G2, it handles the heat well but not stones, it will chip over time. No need to sand but due clean it well and mask the parts you do not want painted. I also would do two coats. I took off all the wheels and placed the car on stands. There is enough paint in the G2 kit to do two coats. Once you finish the 4th one the 1st one will be ready for a 2nd coat. THIS is about the best pic of mine i can find.
Old Dec 24, 2009 | 07:01 PM
Alucard's Avatar
RX8 Club OG
^^^+1... what expo said
Old Dec 24, 2009 | 07:12 PM
djboyd's Avatar
thanks for the help. What would be the benefit of putting a clear coat over it?
Old Dec 24, 2009 | 07:14 PM
StuttgartRX8's Avatar
Nurburgring Camera Whore
I just bought high temp spray paint and did mine has lasted 2 years without any flaking
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
GK1707
Sep 27, 2015 07:33 PM
