View Full Version : Does anyone know where to get a nys inspection with CEL on?
Azam1030
12-24-2009, 09:02 AM
Juice
12-24-2009, 11:11 PM
Don't know the NY laws, but my guess is there is no LEGAL way to get an inspection sticker while the CEL is lit.
Any reason you can't fix the problem and then get your inspection done?
alz0rz
12-24-2009, 11:22 PM
yeah there is no legal way.
this is because ny state requires obd2 compliance, they hook up a DMV-networked computer to your obd2 port and you will automatically fail if you have a CEL lit. the results/test are sent to the DMV immediately.
Azam1030
12-25-2009, 12:40 AM
There is a way to get it push thru, I used to know a shop around here but it was closed recently.
StealthTL
12-25-2009, 01:15 AM
Use a Scangauge or Code reader (or AP) to reset it?
alz0rz
12-25-2009, 01:21 AM
If his CEL is due to emissions (midpipe) then even resetting it won't make him pass because OBD2 tests make sure the car has atleast 100 miles and several drive cycles on it since the previous reset or its another auto fail...
Using an AP with a map that -disables- the CEL will solve this ;]
NYC Drift King
12-27-2009, 03:06 PM
Azam bro do you park your car in from of St. Frances now. i think I see your car everyday now lol. You know im in throggs neck too lol...
gh8st
12-28-2009, 12:24 AM
what al said. just borrow a cat from someone if you need to and take the test
TOMCATS8
12-28-2009, 11:04 AM
put my cat back on but I still have a cel... Do I have to wait a 100 miles before it goes away
alz0rz
12-28-2009, 11:38 AM
reset ecu
TOMCATS8
12-28-2009, 12:42 PM
reset ecu
AIght cool.... Dag I should of know that!!!!
heyarnold69
12-28-2009, 03:43 PM
wait ... i have a cobb ... So i can get it done anywhere?
TOMCATS8
12-28-2009, 07:20 PM
It came right off like butter... im refering to the cel light
TOMCATS8
12-28-2009, 08:05 PM
now im riding around with my cat on but its not hooked up to my catback, so its loud:Eyecrazy:
im going to do my inspection this thursday hopefully
Azam1030
12-28-2009, 11:24 PM
I got it done and yes it is possible
Mr.We$t
12-28-2009, 11:35 PM
Hay bro where u get it done at
jfxp
12-29-2009, 12:27 AM
They do a visual for emissions and inspection. So unless they're stupid they wont pass your car w/o the exhaust on.
jfxp
12-29-2009, 12:32 AM
Lol, maybe that's why they closed ;). There is no "magic button" to push a car through emissions. There are ways around it like running the test w/o signal "disconnected" however if the tech does that too many times they get fined, and the fine is hefty! So unless hes a good friend of yours they wont do it.
