Hey Guys, need a little help
Old Dec 20, 2009 | 11:15 PM
jelly53's Avatar
Smile Hey Guys, need a little help
Hey I'm new here. I have a 2004 Mazda RX8 w/ 52000 miles. Recently the Check Engine light came on and when I checked it out, it says O2 sensor bank 1. The sensor is almost $200 bucks....b4 I do that, could I just try taking the sensor out and cleaning it? Where is the sensor located at? Also the air bag light keeps flashing, is there a way to reset that? The driver air bag was replaced due to an accident. Also how do I reset the TRIP COMPUTER , I wanna see how many miles per gallon I'm doing. Thanks alot!
Old Dec 20, 2009 | 11:29 PM
defacto_dejavu's Avatar
RANA
the trip computer can be reset by just holding the trip stick down for few seconds until it resets. For your other problem, i don't know how to help. You might have to change the module for the airbag to get rid of the light. I assume you replaced it with a used airbag? If the airbag sensor lights up that means there is no guarantee that the airbag will deploy in an accident.
Old Dec 20, 2009 | 11:38 PM
jelly53's Avatar
thanks for your response. But where is that"reset button"??I cant seem to find it.
Old Dec 20, 2009 | 11:45 PM
Jon316G's Avatar
Grasshopper
The owner's manual is your friend.
Press and hold the odometer (or trip meter as its mentioned in the manual) button for more than 1sec to reset it.
The air bag light has been a known issue.
There are connectors under the seats that you disconnect and then reconnect... seems to work most of the time unless you have another issue.
Do a search for this if you want to learn more and find pics.
The O2 sensor code could be the cat failing (assuming its the rear O2 sensor failing).
We would need more details on this (and the exact code too).
Old Dec 21, 2009 | 12:04 AM
jelly53's Avatar
I dont have the manual, but the engine light Code is P0032 and its the front the sensor NOT the back. since it says bank 1 sensor 1 I think. Now I just need to know the location of that sensor. THANKS
Old Dec 21, 2009 | 12:07 AM
CyberPitz's Avatar
Huge hole is huge
He posted a picture that points directly to the "odometer reset switch"...
Old Dec 21, 2009 | 12:11 AM
Jon316G's Avatar
Grasshopper
P0032 is for the front O2 sensor and is located on the exhaust manifold.
Old Dec 21, 2009 | 12:23 AM
jelly53's Avatar
Thanks for your help. So I would have to get under the car to get to it? Do you know any cleaning solution that I could use to clean the O2 sesor once I take it off? Or what can you advise me. should I just buy new one? Thanks again
Old Dec 21, 2009 | 12:34 AM
Jon316G's Avatar
Grasshopper
Yes... you'll need to get under the car to reach the O2 sensor.
Usually the first thing to try is resetting the PCM in hopes that it doesn't return.
1) Turn the key to the 'ON' position (do not start the car).
2) Pump the brake pedal rapidly 20x.
3) You'll see the oil pressure gauge sweep half-way and back down.
4) You can stop pumping at this point and turn the key to the 'OFF' position.
5) Start the car.
If the code returns, you'll need to remove the sensor.
If you take the sensor out and its caked with carbon deposits, you can try a blow torch to break the carbons free, then dip it in water to cool it off.
After that, use compressed air to blow out the remaining particles.
If the sensor appears OK, you might need to replace it.
Old Dec 21, 2009 | 06:24 PM
jelly53's Avatar
thanks for the info. I'll see what happens.
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
M Pizle
Series II Exterior Appearance and Body Kits
Feb 2, 2016 04:47 AM
FoxRacer600RR
Aug 31, 2015 06:32 AM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
