is it my clutch bracket?!?!?
Old Dec 20, 2009 | 09:36 PM
Magana8's Avatar
so i turn my car on drive it for abit and then im stopped somewhere and my car is idling, i start hearing squeaking noise. i accelerate a bit and the squeak speeds up with it. when i put the cluth in the squeaking stops but as soon as the clutch is back out the squeaking starts again.
Old Dec 20, 2009 | 09:37 PM
RIWWP's Avatar
The clutch bracket squeak doesn't depend on speed or RPM, it just squeaks when you push it in, and squeaks when you let it out, regardless of anything else going on.
I'd say this might be connected to your throwout bearing, but I don't know enough about it to be sure.
Old Dec 20, 2009 | 09:40 PM
Magana8's Avatar
well i got brand new engine with about 2k or some miles on it runs fine no problems, its just a squeaking sound when im idle just sitting there doing thing and as soon as i put the clutch in it stops and when i let the clutch go it starts back up again
Old Dec 20, 2009 | 09:47 PM
mattrotary34's Avatar
dont hate...just rotate!!
thats most likely your throw-out bearing from your clutch... its nothing to worry about mine has been doing it for most of its life and i have no problems. its just something you have to deal with unless you want to just replace the clutch
Old Dec 20, 2009 | 09:48 PM
Magana8's Avatar
well when i got my new engine i also got a new clutch installed as well
Old Jan 30, 2010 | 07:15 PM
rotareriot's Avatar
good ole' wankel spanking
i took my car in for this when i first got it and they told me it was just the gears turning over, if your only experiencing it at idle. im not sure though but if it was the throw out bearing it'd make that noise when you push the clutch in, not when you let it out right? idk for sure but mines done that the entire time ive had it and it hasnt caused a problem.
Old May 5, 2010 | 03:23 PM
KDawg23's Avatar
I have the same probelm. My 2005 RX-8 GT squeaks whenever the clutch is out, driving or idling (stays the same regardless of speed). As soon as the clutch is depressed the squeaking stops immediately. It's so annoying, has anyone fixed this?
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
ShellDude
Oct 1, 2015 09:55 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
