Help! Car starts up in limp mode when cold.
Old Dec 20, 2009 | 07:23 PM
remixlp's Avatar
IA Help! Car starts up in limp mode when cold.
For some reason my car keeps starting in limp mode. Sometimes it will start up normal then after i leave it to warm up it goes in limp mode. The end result is that i have to turn it on and off a few times before it starts tor run normally again. what could this problem be?
Old Dec 21, 2009 | 10:30 AM
remixlp's Avatar
no help?
Old Dec 21, 2009 | 10:42 AM
zoom44's Avatar
year and mods please. how long has this been happening. any mods just before it started happening. anyone else drive your car without you just before this started happening. what do you mean by limp mode. what are the actual symptoms?
Old Dec 21, 2009 | 11:01 AM
remixlp's Avatar
It's a 05 gt,
mods, borla exhaust, mazsport dual resonated midpipe.
It only started doing it when the temp drop to about 35 and lower.
The symptoms are, the car revs extremely slow to about 6k and wont go over 25mph.
Old Dec 21, 2009 | 11:25 AM
Is this happening when cold or also when hot?
Old Dec 21, 2009 | 11:42 AM
remixlp's Avatar
This is what happens. I go outside and start up the car, then when it gets warm it starts with the problem. Sometimes it starts up just fine.
Old Dec 21, 2009 | 11:48 AM
Have you cleaned you MAF sensor lately? Any check engine light?
Old Dec 21, 2009 | 12:05 PM
remixlp's Avatar
Yeah i cleaned the maf sensor about a week ago. I have a check engine light because i dont have a cat. You think it may be a bad MAF sensor? There was a period in time where my car would idle irregularly but after i cleaned the MAF sensor, it was fixed.
Old Dec 21, 2009 | 12:16 PM
josuar88's Avatar
The Crawlster
Could be stuck ssv valve?
Old Dec 21, 2009 | 07:00 PM
remixlp's Avatar
No clue.
Old Dec 21, 2009 | 07:30 PM
MartiSpeed's Avatar
get the CEL read. Since you said you already had one (aka its been lit), you wouldnt know if a new one came up...
Old Dec 21, 2009 | 07:31 PM
What CEL's? Could be the MOP....there aren't many things that cause Limp Mode for real
Old Dec 21, 2009 | 07:32 PM
MartiSpeed's Avatar
^^^ he stated he has one already.
Old Dec 21, 2009 | 07:41 PM
I meant what are they exactly...( edited above for clarity )
I have a CEL too...a few of them actually, but the light doesn't tell you how many or what they are......
That is needed info for any kind of diagnosis.
Funny thing is the MOP problem doesn't always throw a code.....ask me how I know...2 weeks of frustration and tracing every wire off the ECU
Old Dec 21, 2009 | 07:48 PM
MartiSpeed's Avatar
haha damn I should have quoted you... now I look like an idiot!!!
Old Dec 21, 2009 | 07:54 PM
That's what edit/delete is for
Old Dec 21, 2009 | 08:14 PM
MartiSpeed's Avatar
... damn us newbs... anyway sorry for crapping in you thread remix, but get your cel checked/run because you never know if you have more than one!!!
Old Jan 31, 2010 | 11:07 AM
remixlp's Avatar
This is still pissing me off. I had it checked for a CEL. There is non, yet it still starts up in limp mode. Im out of ideas here.
Old Jan 31, 2010 | 11:33 AM
You will need to get a lot more specific...and start looking for problems...or you will need to take it in to someone that can do a diagnosis.
There aren't too many things that cause a true limp mode...ECT sensor, MOP, throttle or pedal system errors.....those should throw codes??
Here's something to try...
Reset your ECU....take off the accordion tube on the front of the throttle body
Turn on the key...and see if the throttle plate moves properly......
Then start the car and let it run for a min or 2....and see if the throttle still opens and closes properly.....
Let me know how that ends up
Thechosen1
Jul 26, 2015 09:08 AM
tbiggybig
41
Jul 22, 2015 11:47 PM
thedragonrotar
Jul 22, 2015 08:46 PM
Bomba
Jul 22, 2015 06:46 AM
RX7.9
Jul 20, 2015 12:01 PM
