View Full Version : Block Heater for RX8?
seadooman
12-12-2009, 08:49 AM
Is there such a thing as a block heater for the RX8? And, if so, any personal experiences with one?
It's not that cold yet (well, not as cold as its going to get) and I've noticed it takes a wee bit longer for the engine to catch...gettin' nervous...
expo1
12-12-2009, 09:49 AM
The stick on type seem to be the one most recommended.
www.padheaters.com
AndrewE
12-13-2009, 06:21 PM
When I was in saskatoon mine started in -53c without an issue, IMO its not really warrented
seadooman
12-13-2009, 09:56 PM
Good to know. Maybe its just me getting used to the startup of a rotary...
azzuro
12-14-2009, 12:24 PM
:SHOCKED: And here I was a bit worried mine might not start at -30C. Have you replaced the battery/started with a more powerful one?
Natook
12-16-2009, 12:08 AM
Since convetional oil freezes at -40 give or take a degree or two depending on brand and additives, I doubt the ambient air temp was -53 your probably remembering the temperature with wind chill factor.
AndrewE
12-17-2009, 06:07 PM
Thats what it read on the dash, plus they were having warnings about going outside on the weather network due to the extreme cold, saskatchewan is a cold place.
I should add that my coolant was good until -45C and it didn't freeze, when it comes to stuff freezing up the temp would have to remain constant and the car unused for any of that freezing point crap to apply
AndrewE
12-17-2009, 06:09 PM
same battery as when purchansed used March 07, appears original.
Railton
12-17-2009, 08:26 PM
You my friend should be buying lottery tickets.
Railton
Natook
12-17-2009, 10:01 PM
I live on the prairie and grew up in Northern alberta. I know cold as well, I have had oil freeze in the pan, and it only take a few hours for it to happen at extreme temperatures. Anti freeze doesn't stop your oil from freezing.
The lowest temperature ever recorded in Saskatoon was -50°C in 1893.
seadooman
12-17-2009, 10:27 PM
-20C in Ottawa this morning. Started like a charm. I feel better. Although it certainly takes a few more cranks over than a piston and sounds different...
9krpmrx8
12-17-2009, 10:35 PM
Holy shit, I could never live in temps that cold.
DarkBrew
12-18-2009, 03:00 PM
I used a pan heater I bought on Ebay. The oil was much warmer at start up.
AndrewE
12-18-2009, 06:55 PM
My in car temp said -53 at like 6am in feb/March 08 I think it was, and car started fine, albiet high idle and loping. 5w20 is pretty dam thin, and the rotary hasn't got much in the way of moving parts. All I'm saying is that RX8 is fine in winter as is, rust and traction issues aside.
the 85 Corolla SR5 I'm driving now barely started this morning in -22 or whatever it was
