View Poll Results: Did you experience water or heavy condensation in your tail lights?
Yes, my RX-8 is a 2004 model
54
55.10%
Yes, my RX-8 is a 2005 model
30
30.61%
Yes, my RX-8 is a 2006 model
0%
Yes, my RX-8 is a 2007 model
1.02%
Yes, my RX-8 is a 2008 model
0%
No, never.
13
13.27%
Voters: 98. You may not vote on this poll
Poll: Water in tail lights
Old Dec 11, 2009 | 03:32 AM
ClarityMD's Avatar
I know there are a million threads on this, but I never saw a collection of data on it.
Please participate in the poll.
One reason I'm asking is my warranty is expiring in a bit over a week, but it's a fairly new car (2005) w/ low miles.
I get the impression the water leak happens 100%, but this thread should clarify it.
Old Dec 11, 2009 | 04:06 AM
cjkim's Avatar
^noob
voted ^^
never had a problem, but the car is now RIP as of 10/30/09
socal, 2004, original tails
it did see rain sometimes, but obviously, being from socal, it wasnt all that much.
Old Dec 11, 2009 | 04:17 AM
SayNoToPistons's Avatar
Wheels, not rims!!
Yes, after I drove it the first time in a rain storm. It would sit under a cover on the driveway in the rain or sometimes without cover, never had a problem until I drove it during the rain storm. Passenger side repaired with silicon adhesive and I think I have to do the driver side again because I see some moisture again.
Old Dec 11, 2009 | 05:57 AM
Bigbacon's Avatar
2006 WB AT
I saw an 8 last friday that had at least a 1/2 inch of water in the one tail light.
Old Dec 11, 2009 | 01:55 PM
ClarityMD's Avatar
thanks for all the input so far!! great data right now...
Old Dec 11, 2009 | 02:14 PM
Easy fix. Black RTV. The updated gasket is BS.
Old Dec 11, 2009 | 03:11 PM
CyberPitz's Avatar
Huge hole is huge
Negative with my 07.
09's get the shaft with this poll
Old Dec 11, 2009 | 03:23 PM
ODDDOOD's Avatar
The DOOD abides.
My '04 had issues after taking delivery in the first year and they were corrected a few times over the next couple years. The most recent breakthrough was 15 days after my extended warranty was out. Passenger side rear tail-light is fubar...I think I will take it off and and place in a 5-gallon sealable container with a few large desiccant packs to get the moisture.
I have not taken the light housing off before, but where exactly do you put the RTV? Does it seal just the housing, or do you put it where the gasket typically goes?
Thanks in advance!
Old Dec 11, 2009 | 11:43 PM
derek54's Avatar
I've never seen the need for a brand new gasket. unless of course its crumbling apart. But I just took mine off and resealed it with silicone. no fogging since.
ODDDOOD - You put the silicone where the gasket is pressed up against the housing itself. nothing to do with the seam where the plastics connect.
Old Dec 14, 2009 | 09:14 AM
ODDDOOD's Avatar
The DOOD abides.
grazie!
Old Dec 14, 2009 | 09:32 AM
bsteimel's Avatar
Nice !!!
I had condensation in my driver side shortly after i bought it in 2006. Its a 2004 model, it was fixed with the updated gasket (tsb) and I haven't had a problem since. I live near Philadelphia, so i get plenty of rain. It hasn't been garage kept until about 6 months ago.
Old Dec 14, 2009 | 10:26 AM
alfy28's Avatar
yep my 04 has water in its passengerside tail lights. sucks because i taken it in 3 years ago to have it fixed. now 3 years later , i am back to square one with no warranty
Old Dec 14, 2009 | 01:58 PM
nikkdizzle's Avatar
Daddy's Home...
we've recently got rains over the past week and it looks like i have a fish bowl going on in my tail lights! yay!
Old Dec 14, 2009 | 02:09 PM
JRichter's Avatar
Void Where Prohibited
Left side happened first - dealer replaced entire light but wouldn't do right side until condensation showed up. When it finally did I just used some silicon gasket maker or something to create a new seal over original, shitty, oem gasket and used a vacuum on reverse to dry out inner assembly. Never had a problem since then (1.5 years ago). Cost of repair: $3.
Old Dec 14, 2009 | 02:30 PM
r0tor's Avatar
same here
Old Dec 14, 2009 | 03:51 PM
CTrx8's Avatar
space for rent
bought mine used private party and there was condensation. had it replaced under warranty a few years ago and haven't seen it again since. of course b/c i posted this, i should expect to see some in my tail lights tomorrow.
Old Dec 14, 2009 | 03:54 PM
initialsin's Avatar
I had one replaced, then it rained and then the other one started. So i got mazda to replace both of them.
Old Dec 14, 2009 | 08:46 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Fortunately, my car doesn't sit in the rain too much or I'm sure I could keep gold fish in my tail lights. After warranty, it seems the best method is dry it out and silicon seal it tight.
Old Dec 14, 2009 | 09:52 PM
MrAdam5's Avatar
I had this problem in both tail lights back in May this year when I got my car (a 2004). Replaced what I guess were the original gaskets with new ones. Now, yesterday, I noticed a very small amount of frost (-30C here) in the driver-side light... ugh. I'll be sealing with a liquid gasket this time round when it warms up.
Old Dec 14, 2009 | 10:24 PM
rev8's Avatar
so it's a V twin?
just got my right one looking like a fish tank on sat. this sucks
Old Dec 14, 2009 | 10:28 PM
HockeyRX-8's Avatar
TNC
nope...no issues here
Old Dec 15, 2009 | 05:14 AM
foo77's Avatar
4th batch : Apr 03'
should add 2003 model too
Old Dec 15, 2009 | 06:31 AM
Huey52's Avatar
Registered Zoom Zoomer
Yep. 2005 and both tailights replaced under warranty. New gaskets are holding fine tho'.
Old Dec 15, 2009 | 07:21 AM
MICHGoBlue's Avatar
05, left tail light, replaced under warranty.
Old Dec 15, 2009 | 10:11 AM
Wrathre's Avatar
Swimming in my tail light
05, driver side tail light, just started about 3 months ago, resealed once (apparently poorly) because condensation started building again recently. To my defense, it's been raining non-stop for like a few weeks now, damn you GA weather...
Will attempt to reseal again soon, probably in the next day or two. Shall post results.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
erikcamacho15
Sep 12, 2015 11:23 AM
