Coolant Question...
Old Dec 10, 2009 | 02:07 PM
rx8-808's Avatar
Coolant Question...
Hi guys, I tried checking the forum for the answer to this, but I could not find a definitive answer: What kind of coolant do you use? I have a 2005, and I checked the manual, the coolant cap, and under the hood and there was no info on what specific coolant to use. I went to my local NAPA and asked the guy there and his computer couldn't tell him either. The manual says something about not using an alcohol (and other chemicles) based coolant, which the guy from NAPA replied that it's probably a Mazda proprietary coolant. This was just too hard to believe that a coolant would be proprietary. I stuck a scribe in the tank to get a couple drops in sight and it was green...so I figure just a 50/50 mix of green coolant and water should be sufficient...what do you think? Thanks so much.
--Phil
Old Dec 10, 2009 | 02:19 PM
I just use prestone from any auto parts store. Big yellow jug.
They sell a pre-mixed with is 50% coolant / 50% water.
I buy the concentrated coolant since I run closer to 70% water / 30% coolant. (it's not cold here and summers are quite toasty)
Usually the 50/50 works best for all around climate unless you're out in the desert or extreme cold. Mazda ships the cars with a 60/40 mix
Old Dec 10, 2009 | 02:26 PM
Leonardo Rosas's Avatar
partyboy007
i use the same prestone yellow jug i use full strength since i live in seattle hitting the teens right now brrr
mazdaverx7's Avatar
RX-Heaven
also, because of the extensive use of aluminum in the engine, i change my coolant once a year. if the coolant is left unchanged year after year, the area around the coolant seals and the jackets will corrode. the engine will then require new rotor housings. i have seen this many times over the years with RX-7's. this has made me a stickler for changing the coolant.
Old Dec 10, 2009 | 03:16 PM
+1 to yearly flushes, I've been doing that since I bought the car and it's worthwhile maintenance.
OR...
you can be like NYCGPS who I believe has changed out his coolant at least 3 times already this year!
Old Dec 10, 2009 | 10:42 PM
rx8-808's Avatar
Awesome, thanks for the advice. I'll probably use a less concentrated formula since it never gets below 60 here.
Old Dec 10, 2009 | 11:42 PM
TZ250's Avatar
50/50 provides freeze protection to something on the order of -35F. High coolant concentrations transfer heat very inefficiently and will make the car run hotter.
Old Dec 13, 2009 | 02:49 PM
ken-x8's Avatar
Mazda does sell a prorietary coolant, FL22, which is diluted green glycol. I think someone posted that it's 55/45, not 50/50, but that's in the same ballpark. FL22 is supposed to be good for 10 years.
Since yours is green, definitely keep using green and not orange. There's a TSB that says mixing green and orange will work OK, but will turn black which tends to upset customers.
Ken
Luiss7
54
Aug 20, 2019 08:56 AM
Azki23
Jun 27, 2018 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
