Agency power exhaust dyno sheet.
Old Dec 9, 2009 | 01:35 AM
Corey's Avatar
Anyone have the dyno sheet for the AP exhaust? I've been looking,but i haven't had any luck finding it. If anyone could post it, i'd appreciate it.
Old Dec 9, 2009 | 02:23 AM
Easy_E1's Avatar
Your looking for power increases from a cat back? OK. Good luck.
Old Dec 9, 2009 | 02:26 AM
RyansRx8's Avatar
Brettward is/has a G
+3hp on a good day
Old Dec 9, 2009 | 02:33 AM
arlingtonrx8's Avatar
05 A/T Base - 05 M/T GT!
1-3 for every catback... unless you go negative. Go for sound.
Old Dec 9, 2009 | 02:35 AM
RyansRx8's Avatar
Go midpipe too, you'll see some better numbers
Old Dec 9, 2009 | 01:01 PM
Corey's Avatar
Well, if i'm only going to get roughly 3 more HP from it, then what would be a better exhaust?
Old Dec 9, 2009 | 01:11 PM
Solidtrance's Avatar
That was 1-3 on a good day, not 3 for sure, and any off the shelf catback is like that. Not worth it for the power, now sound on the other hand will change a bunch.
Power-get a midpipe.
Sound-get a cat back.
Old Dec 9, 2009 | 05:48 PM
Rocketman1976's Avatar
Tailgaters beware
I did the full Agency Power 3" with cat delete pipe, I have a dyno sheet showing 12.5 rwhp and 6 or 7 rwtq gained in 90 degree weather with that setup.
I did run it with the stock cats back in for a while, and you could definitely feel the loss of hp in the higher revs.
Billy Marcial
Mar 1, 2018 06:50 AM
Jazzmeson
Aug 6, 2015 04:34 PM
Jazzmeson
Aug 6, 2015 04:32 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
