Change the paddle shifters?
Old Dec 8, 2009 | 09:16 AM
Bigbacon's Avatar
2006 WB AT
Has anyone ever done this or even thought about?
I like the paddles but the down buttons just plain suck. I always up to shift up with my left hand and down with my right by using the paddles.
Do you think it possible to re-wire those things?
I would be all for disabling the down buttons and just making the right paddle do the down some how.
Old Dec 8, 2009 | 11:45 AM
09Factor's Avatar
Original Turbo 'd Auto !!
I've comtemplated this myself.
Left = Upshift and Down = Right
They are just connected by wires and the shifters use a simple Cherry NO switch. Very close to what you would find in an upright arcade console.
Switch the wires to you liking and you should be set.
have a service manual ? I don't know if the 04 manual would be the same wire chart as the 06+
Old Dec 9, 2009 | 07:11 AM
Bigbacon's Avatar
2006 WB AT
hmm. Wonder if I can get another AT wheel and an MT wheel somewhere cheap and just swap parts around. That way I wouldn't have the down buttons at all.
Anyone have an AT or MT wheel laying around with or without the airbag??
Old Dec 9, 2009 | 08:21 AM
JinDesu's Avatar
went back to srsly broke
You mean have the up buttons added to the MT wheel?
Old Dec 9, 2009 | 08:43 AM
Bigbacon's Avatar
2006 WB AT
I was thinking using mixed parts from each wheel type so that it would effectively be an AT wheel just the with front of an MT without the down buttons.
Old Dec 9, 2009 | 08:49 AM
JinDesu's Avatar
I'm not too sure, but I could swear the down buttons are placed on the back of the steering wheel, not the front cover.
I hope what I'm saying makes some sense lol.. I'm at work and can't go see my car
I actually like the shift up and shift down buttons the way they are right now; I often drive with my left hand on the wheel and my right hand either on the shifter, or messing with the AP. When I need to shift up while the wheel isn't turned too far, I just hit up and down with my left hand. When I need to shift when I have to turn the wheel a lot, I use the shifter instead.
Old Dec 9, 2009 | 09:20 AM
Bigbacon's Avatar
2006 WB AT
I have a very hard time using my thumb to hit down. specially when turning and other wise it's like my brain just doesn't want to use them. I often end up hitting the up paddle when I really want to go down.
I've tried just using the shifter but I don't care for personally. I normally drive with both hands on the 3 and 9 of the steering wheel.
It's like paddles are ingrained into my brain as one should be up and one should be down.
I'll have to examine the steering wheel more.
Old Dec 9, 2009 | 09:30 AM
JinDesu's Avatar
Yeah, I understand where you are coming from. I was originally used to right-up, left-down pull-paddles.
If you were to change the MT front of the steering wheel with the AT, I think you get the same effect as just taking off the down buttons. You could probably saw off the protrusions on the back part of the steering wheel that support the button, and re-wire it to your liking. I would say getting a spare AT wheel would be better, so you can mess around with it to see what you need exactly.
Old Dec 13, 2009 | 04:30 AM
Nopstnz8's Avatar
I've been contemplating this for a while, but never knew if it was truly possibly. I would probably get an MT wheel, then get some paddles from another car, and try and mount them.
Old Dec 13, 2009 | 11:50 AM
nuke0907's Avatar
Never Blend In
have you guys checked out Works Bell?
Old Dec 13, 2009 | 11:57 AM
mike[piston eater]'s Avatar
O' Let's do it.
yeah works bell makes a sick aluminum paddle shifer, that you could efectivly use with a quick release
Old Dec 28, 2009 | 09:42 AM
09Factor's Avatar
I was looking at the AT steering wheel and the looks like the "Down" paddles are part of the pieces that house the volume +/- controls, cruise control, ect. Swap in the MT steering wheel one's and make one of the "Up" paddles a "Down".
I'll do this when I get my 8 back.
Old Apr 10, 2017 | 08:41 AM
Johnson Yong's Avatar
Can we change the AT steering wheel to at MT ??
while keeping all the wheel controls.
Old Apr 24, 2017 | 07:08 PM
09Factor's Avatar
Wholey Threadsurection Batman!!!
I believe the harness is the same.
Old Apr 27, 2017 | 04:34 AM
Did you finish this mod 09Factor?
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
LB2739
Jul 9, 2019 02:25 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Irvinb16
Sep 11, 2015 10:27 PM
