View Full Version : Terrible ceramic brake squeal only 5k old
josuar88
12-07-2009, 06:30 PM
Ok so I did some searching and I found that the brake pads I have are well not good Wagner thermo quiets are as quiet as Micheal Jackson dying. It seems to have gotten worse now that its colder here in Washington. Not only do I get some squeal while initially slowing down I now get a loud squeal stopping from 4mph and down its terrible and makes me want to punch babies. So question is since these brake pads are less then 5k old what should I do? Also these were all replaced at the same time with lube put in appropriate places.
cyclone1208
12-07-2009, 06:34 PM
huh i have the same pads but mine are quiet...however it was just recently installed not even 1k on em
josuar88
12-07-2009, 06:39 PM
Only reason I bought them was because it was the only ceramic brake pad the auto parts stores where I lived had front and rear in stock.
cyclone1208
12-07-2009, 06:53 PM
Is there a way to return em? I'm sure there is some sort of warranty
volcomx31
12-07-2009, 06:56 PM
from what i know, the rx8 pads squeal when its cold..
josuar88
12-07-2009, 08:00 PM
My buddy says that because they are ceramics this is normal and annoying at least I guess I should pick a more driving friendly brake pad next time.lol
dillsrotary
12-08-2009, 08:12 AM
I have hawk ceramics from tirerack.com and never had them squeal, plus i have about 20k miles on them. Did you bed them correctly after first installing them?
RIWWP
12-08-2009, 08:33 AM
Check out this information. It is a great read, and might help answer your issue. I would suggest re-bedding them, since even if you bedded them in the first place, they may have been un-bedded through light use.
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
If you have time, dig through all of their articles, they have some really great stuff about brakes.
Huey52
12-08-2009, 08:48 AM
Hawk Ceramics myself and near silent and very low dust. Be sure to bed-in (aka burnish) your pads properly no matter which you choose.
Razz1
12-08-2009, 10:01 AM
Did you use the bake squeal goop on the back side of the pads?
RIWWP
12-09-2009, 09:51 AM
Read this whole article and watch the video. I bet re-bedding will solve your problem.
http://www.essexparts.com/learning-center/cat/brake-rotors/post/Bed-in
josuar88
12-09-2009, 09:59 AM
Ok I re bedded them last nite and I did use the brake goop that came with the pads. Ill tell you the results of the re bed and will post up a video of the noise if it continues.
