Car Died at idle last night
Old Dec 7, 2009 | 03:44 PM
Old Rotor's Avatar
Originally Posted by matt1888
So after getting out of work and starting my car and letting it warm up a ways before even driving, I pulled into a gas station and put it in park and was sitting there listening to the stereo when my car started acting weird.
I felt the engine kind of stutter and than it died and my DSC and traction control lights came on and were blinking. I than restarted the car and everything worked fine.
I have thought I noticed for the past couple months my dash lights somewhat dimming and than becoming bright again.
Anyone know what the heck is going on?
Please give us the history on your car. The service it's had parts replaced. Did you do all four coils , wires and plugs? Type of driving it gets(long commutes, short trip), fuel used(reg or prem), ever flooded. Just any thing that you can add. Have you cleaned your MAF sensor? Done any decarbon cleaning?
Old Dec 7, 2009 | 06:18 PM
invasion08's Avatar
First check you battey connections, make sure they are clean and tight.
Old Dec 7, 2009 | 11:19 PM
Old Rotor's Avatar
What year, miles, M/T or A/T?
Old Dec 8, 2009 | 02:09 AM
iLikeEatPoo's Avatar
The Great Dick
battery light come on? Alternator might be on it's way out.
Old Dec 8, 2009 | 10:03 AM
Sounds like a battery.
Also sounds like you need to go to the local community college and take your basic automotive class.
Old Dec 11, 2009 | 02:09 PM
silverkillrx8's Avatar
Ive had this same problem, one thing i did was put the stock air filter back on and it was fine but it seemed to be as soon as i put my cold air intake back on it started doing it again.
Old Dec 11, 2009 | 06:45 PM
Check the cable connections, recharge the battery.
Old Dec 11, 2009 | 06:50 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
"and put it in park"
Might be a hint.............I know you're trying to help, just thought I'd point that out.
Old Dec 11, 2009 | 06:54 PM
Mazurfer's Avatar
Yep, start with the easy stuff.
Check your connections at the battery and see if they are clean and on solid.
If you know how to use a meter, you should read about 13.9-14.2 volts on the battery with the car running........that will not eliminate the alternator 100%, but it will be close to doing so.
If you have access to an autozone or pepboys or something like that, they may test your battery for free........they'll also check the alternator at the same time. Because you noticed the lights dimming before this happened, IMO it's probably your battery on the way out and it dragged down the alternator(so to speak).........or you got dirty terminals. You have an aftermarket sound system?
Old Dec 13, 2009 | 11:33 PM
i do have an aftermarket system but i have a capacitor for it its only very so often that mine does it..
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
tbiggybig
41
Jul 22, 2015 11:47 PM
