Can one of you geniuses tell me how to....
Old Dec 7, 2009 | 01:03 PM
ShottsCruisers's Avatar
Rx7 and now Rx8
....OK...my '06 developed it's first (and it's annoying) creak/rattle over the bumps and rough roads. It stops if I push in on the bottom right corner of the shiny center dash piece...you know, just to the right or bottom right of the temperature adjust ****.
Know how I can tighten that spot up? Please help this Dash Dummy?
Old Dec 7, 2009 | 02:34 PM
jmc23200's Avatar
Look up the removal instructions for the radio. That will get you underneath the plastic. Then, drive around with the plastic off so you can pin point the rattle. Most likely a loose screw or something. Good luck
Old Dec 7, 2009 | 02:42 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Or look in the epic "rattle hunt" thread.
https://www.rx8club.com/showthread.p...ht=rattle+hunt
Maybe someone else has already had it and cured it?
Old Dec 7, 2009 | 03:02 PM
Rx7 and now Rx8
The Rattle Hunt thread was hilarious! I guess I've been lucky so far. I'll search for radio removal. Thanks!
ScudRunner
61
Oct 10, 2010 07:34 PM
To be named later
May 19, 2008 08:07 PM
