Changed Battery Car doesn't hold idle!
Old Dec 6, 2009 | 02:47 PM
tza0001's Avatar
Dum Spiro Spero
As title says the car does not hold idle after putting in a new battery (Red Optima). Do I have to reset the ECU? I have an 04 with 52,000 miles. Spark plugs, wires, and coils were changed at 40,000 miles. Any help is appreciated.
Old Dec 6, 2009 | 02:54 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
By putting in a new battery, you pretty much did an ECU reset. When you disconnected the old battery for more than a few minutes, it reset.
Car is re-learning the fuel trims so it might take a few drive cycles to settle down.
Don't freak out too much, give it a few drive cycles and then let us know if that doesn't cure it.
Old Dec 6, 2009 | 03:03 PM
tza0001's Avatar
Dum Spiro Spero
Thanks for your quick reply! I am going right now to drive the car for a bit and I will let you know.
Old Dec 6, 2009 | 03:05 PM
Mazurfer's Avatar
Drive cycles = driving the car, shutting it off, and then driving again.......a few times.
Oh..................and DON'T shut it off cold!!!!!
Old Dec 6, 2009 | 03:57 PM
tza0001's Avatar
Dum Spiro Spero
Everything worked fine! I drove the car around for a while. I did 3-4 drive cycles and the car seems now to be fine! Thanks a lot for your valuable input!
Old Dec 6, 2009 | 06:52 PM
Mazurfer's Avatar
You're Welcome.
Glad that was it....although I was 98% sure, it could have been something else.
Jesus Martinez
44
May 6, 2025 08:09 AM
9krpmrx8
Nov 5, 2015 11:45 PM
dbarber
Jul 25, 2015 01:34 PM
netrovers
Jul 20, 2015 03:32 AM
