Loud "clicking" from driver side
Old Dec 1, 2009 | 05:56 PM
blamerobb's Avatar
So I think that my control / a arm is going out. After I dropped my car I noticed a click. Now it is horrible. My buddy days it my a arm bushings they went out now it's metal on metal which sounds to be correct. It hapens when I take speed bumps or turns. Basically whenever the driver side and now the passenger side suspension compresses or decompresses
What u guys think
Old Dec 1, 2009 | 06:04 PM
Jon316G's Avatar
Grasshopper
With the front jacked-up, place a long piece of wood or a long bar under the tire and pry the tire upward and listen for a "clunk" sound as you move the tire up and down.
Old Dec 1, 2009 | 06:32 PM
More likely to be the end link......
Old Dec 1, 2009 | 06:34 PM
Jon316G's Avatar
Grasshopper
When I broke my end link I didn't know about it for several months and it wasn't until I was bleeding my brakes that I noticed it.
I never had any clicking sounds because of it
But you never know... anything is possible.
Old Dec 1, 2009 | 06:38 PM
blamerobb's Avatar
I have ap endlinks. And what dose jackin the tire up do. I know that's when the sound comes
Old Dec 1, 2009 | 06:42 PM
Jon316G's Avatar
Grasshopper
This will tell you if you have a bad ball joint.
I had a similar issue with my F150 and had to replace it.
Old Dec 1, 2009 | 06:55 PM
blamerobb's Avatar
But what do I look for? I can hear it just don't know what to look for ? And the ball joint is at the top of the a arm
Old Dec 1, 2009 | 06:56 PM
blamerobb's Avatar
dammit I'm at mazda getting my oil done and they couldn't get it to click. I know how too. Dammit
Old Dec 2, 2009 | 09:07 AM
blamerobb's Avatar
Bump for knowledge
Old Dec 2, 2009 | 10:06 AM
bsteimel's Avatar
Nice !!!
Might want to check the TSB related to bolting down the lug nuts. http://www.finishlineperformance.com...2-04-1301b.pdf
I would have clicking on one wheel when turning. It was like the TSB said under slow turning but i noticed at speeds of around 15 mph around tight corners or stop lights. I torqued the wheels harder and it went away. Doesn't sound like its exactly it but it might be. Its a real quick check so i would think worth a look.
Old Dec 2, 2009 | 10:10 AM
The Reverend's Avatar
That's a lie
^+1 robb check your lug nuts same thing was happening to me
Old Dec 2, 2009 | 11:23 AM
blamerobb's Avatar
Thanks for the link I'll have to try that out. Did u sand and clean as it says?
Old Dec 2, 2009 | 01:38 PM
bsteimel's Avatar
Nice !!!
All i did was just wipe it with a rag real quick to make sure there wasn't any sand or grit between the 2 surfaces, but i didn't get any sandpaper out. I think its really just the torque specs it goes from 65 to 108 ft/lbs, that's quite a difference
Warrior777
Jun 24, 2019 04:47 PM
TeslaMSI
Dec 10, 2015 01:10 AM
vapor2
Oct 8, 2015 02:08 PM
