Battery/Start Upgrade, any recommendations?
Old Nov 30, 2009 | 10:10 PM
tamz273's Avatar
Hey guys,
Im looking to upgrade my starter and battery to prepare for the cold winter. I can feel my car starting to get weaker on ignition, and I have never changed my battery (69k).. I also have the original starter on the 04 model, so I'm looking to upgrade that while I'm at it.
Which starter to you guys recommend? I know there are a few out there..
Which battery should I go with? Im looking something with hi amp's because I have a car computer running that sucks alot of power, and I use often when the engine isnt running..
Old Nov 30, 2009 | 10:26 PM
Jon316G's Avatar
Grasshopper
Didn't know BHR and MazSport made starters
Anyway... You can try the buy/sell section of this forum and hope to get a deal on a used one.
Or buy it new from vendors like MazMart:
http://mazmart.com/PartsList.aspx?id=30&n=NEW&m=6
For batteries, I've been a fan of Optima (you would benefit from the yellow top)
Old Nov 30, 2009 | 11:04 PM
As much CCA as you can find.
750 Cold Cranking will be fine for the cold winter.
Old Dec 1, 2009 | 08:28 AM
tamz273's Avatar
Whats the difference between the red top and the yellow top?
EDIT:
Did some research.. Looks like im gonna get the red top for the starter, and then a yellow top + Isolater for the car computer.. Pricey but worth it IMO..
Old Dec 1, 2009 | 09:46 AM
EDZRIDE's Avatar
2005 White GT
Sears Platinum Diehard!
Old Dec 1, 2009 | 09:53 AM
Huey52's Avatar
Registered Zoom Zoomer
The uprated starter is well advised.
Don't forget coils, 'plugs and cables. And verify your alternator belt tension and output (~14v) as well. They're all related to starting/running goodness.
You may want to consider the BHR ignition system (includes GMC Yukon coils and MSD cables). They can also get you a good deal on Iridium 'plugs.
I now also advocate the Diehard Platinum P-5 Group 35 over Redtop.
Old Dec 1, 2009 | 10:12 AM
Vlaze's Avatar
The Angry Wheelchair
I thirdly recommend the diehard unless you're a weight savings fanatic
Old Dec 1, 2009 | 10:35 AM
Huey52's Avatar
The Redtop is a bit heavier than the OEM Interstate as well. It's the price you pay for more rugged and higher sub-component quality construction.
Old Dec 5, 2009 | 04:45 PM
Spirograph's Avatar
I'd like opinions on starter brands too; I have the '04 stock starter now. I've swapped my battery for a reverse post yellow top, and so far it's been working fine. The CCA is less than the red top, but I like the yellow in case I need to deep cycle to de-flood.
Old Dec 6, 2009 | 10:03 AM
Huey52's Avatar
^ you definitely want the uprated Mazda-branded starter. A good battery is great, but if the starter-engaged flywheel isn't turning fast enough ....
A couple vendors here still have them., including I believe Finishlineperformance.com (drop Tommy a note).
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Quiggs321
Sep 30, 2015 05:34 PM
drlubell
Sep 26, 2015 11:58 PM
