View Full Version : Maximum speeds in gears
NickG 01-15-2004, 03:33 PM Hi all. Does anyone have precise info on the maximum speeds in each of the 8's six gears at redline? I don't own one ( yet! ) but am curious. During my two test drives I've been too busy watching the tacho to notice the speed at the upchange points! Not that easy to do so in any case as the digital speedo seems to me to be a bit of a jumble when you are accelerating hard! (Tried to search on this but without luck - maybe my keywords were wrong).
Peggy 01-15-2004, 03:57 PM (1) 41 MPH
(2) 68 MPH
(3) 94 MPH
(4) 130 MPH
(5) 150 MPH
(6) 150 MPH
Hey, I got this from an article by Automobile Magazine I got at the dealer. These aren't my numbers, so if anybody records anything different, feel free to correct me.
Oh, and by the way, I'm not "Peggy". This forum seems to have a problem with user sign on's. I hope someone else won't be able to hack into my profile when I get my own username.
DragonStar4681 01-15-2004, 03:58 PM i think first at redline is about 40 thats all i know. :)
Chef RX-8 01-15-2004, 04:32 PM I was able to get to 43 at 9000 RPM's in first and then 71 in second.
FirstSpin 01-15-2004, 04:35 PM I've been to 91 in 3rd....
MikeA 01-15-2004, 05:44 PM Good luck getting the right numbers.....since everyone is a chicken around here when it comes to hauling ass.....
Jeff_pap31s 01-15-2004, 06:50 PM Now that was comedy!!!
flatso 01-15-2004, 06:54 PM Has anyone seen the recommended shift points in the owner's manual...it's pretty funny. Try to shift at those speeds sometime.
grogiefrog 01-15-2004, 07:08 PM The MT is an AT with being able to do 40 in first. This covers a lot of city driving!
NickG 01-15-2004, 07:08 PM Thanks for the info. 68mph in second? ...now THAT's COOL!:cool:
grogiefrog 01-15-2004, 07:19 PM Now where does the AT shift?
red_rx8_red_int 01-15-2004, 10:02 PM I think the first three are right on, I hit 41 twice today in first, and 68 for second and 94 for third sound exactly right from memory. Have not tried 4th 5th or 6th. Really never drive in 6th unless on a road trip, put in 6th and set cruise control to 85. In my daily cummute I typically drive in 4th until around 80-85 depending on traffic.
idle0ne 01-16-2004, 01:30 AM wont driving in 4th doing that fast and never hitting 5th or 6th burn gas faster?
StealthTL 01-16-2004, 03:30 AM They sound right, I have had the buzzer going, in 5th, which is relatively qiuck....
The Japanese spec cars have a limiter (138mph, if I recall)
but there is NO limiter on the US model. Someone posted that on a dyno they took it to 178mph, indicated.
S
red_rx8_red_int 01-16-2004, 06:49 AM Originally posted by idle0ne
I'm sure it does. I typically get about 15 mpg. I tried a couple of times to drive granny style (use the shift points in the manual) but can never go through a tank doing it. For example, I'll fill up making a mental note to try to drive conservatively for this tank of gas, and end up peeling out from the gas station. The FUN factor is just too much. I've given up trying to maximize my mpg for a while. Maybe if there's snow on the ground for a complete tank period I might find out the best mpg I can get. But for right now I don't care, I have almost 10k on the car and still concentrate on fun, not best mpg.
beachdog 01-16-2004, 02:26 PM There was a prior posting about this and a reference to a website with a speed in gear calculator. Here's the website:
http://rogerlarsen.home.comcast.net/ratio.html
Here's the calc it gives for 9000k
1. Accelerating to: 9000 rpms gives a speed of: 40.37 mph..
2. at 5431. rpms. Accelerating to: 9000 rpms gives a speed of: 66.91 mph..
3. at 6524. rpms. Accelerating to: 9000 rpms gives a speed of: 92.29 mph..
4. at 6494. rpms. Accelerating to: 9000 rpms gives a speed of: 127.90 mph..
5. at 7582. rpms. Accelerating to: 9000 rpms gives a speed of: 151.82 mph..
6. at 7587 rpms. Accelerating to: 9000 rpms gives a speed of: 180.09 mph..
Disclaimer .. The results of this calc is based upon the stock tire diameter reported by
bridgestone (25.7 inches). The ratio on the differential is calculated to 4.5589:1 based
on 3750 rpms at 75 mph. The gear ratios are off the rx8 specs:
1. 3.76
2. 2.269
3. 1.645
4. 1.187
5. 1
6. 0.843
The calc does not use wind resistance and/or other external factors when calculating the results.
red_rx8_red_int 01-16-2004, 02:53 PM Nifty calculator. The rev limiter is above 9000, so I punched in 9200 and got the following results.
1. Accelerating to: 9200 rpms gives a speed of: 41.27 mph..
2. at 5551. rpms. Accelerating to: 9200 rpms gives a speed of: 68.39 mph..
3. at 6669. rpms. Accelerating to: 9200 rpms gives a speed of: 94.34 mph..
4. at 6638. rpms. Accelerating to: 9200 rpms gives a speed of: 130.74 mph..
5. at 7750. rpms. Accelerating to: 9200 rpms gives a speed of: 155.19 mph..
6. at 7755. rpms. Accelerating to: 9200 rpms gives a speed of: 184.09 mph..
beachdog 01-16-2004, 03:13 PM Looking back at this calculation, it reminds me that i was certain that I had shifted into 3rd at 70mph with the rev buzzer going during my road test. Haven't done this in my own yet.
red_rx8_red_int 01-16-2004, 10:15 PM It's been posted someplace here that the Renesis has actually been tested to be somewhat reliable at 12k rpm! The following is the result gotten when 12000 is punched in to that calculator (note this clearly ignores many factors):
1. Accelerating to: 12000 rpms gives a speed of: 53.83 mph..
2. at 7241. rpms. Accelerating to: 12000 rpms gives a speed of: 89.21 mph..
3. at 8699. rpms. Accelerating to: 12000 rpms gives a speed of: 123.05 mph..
4. at 8658. rpms. Accelerating to: 12000 rpms gives a speed of: 170.53 mph..
5. at 10109. rpms. Accelerating to: 12000 rpms gives a speed of: 202.42 mph..
6. at 10116 rpms. Accelerating to: 12000 rpms gives a speed of: 240.12 mph..
sferrett 01-16-2004, 10:50 PM Well here's me at the top of 4th gear last weekend - unfortunately the flash reflected off the spedo and I didn't have the presence of mind to look at the preview (ugh - just taking the photo was ridiculous enough).
Anyhow - I think the speedo was reading something like 131...
Gord96BRG 01-16-2004, 11:37 PM Originally posted by beachdog
1. 3.76
2. 2.269
3. 1.645
4. 1.187
5. 1
6. 0.843
If you're looking up transmission gear ratios, why wouldn't you just grab the differential gear ratio while you're at it?? ;) The diff ratio is 4.444:1, no need to back-calculate it.
Regards,
Gordon
gingersrus 01-17-2004, 12:24 AM Originally posted by sferrett
I could swear I see the fuel gauge moving down, and it's a STILL PHOTO!
WOW! You guys are crazy!
(Not a flame, just an expression of amazement from a much more conservative driver.)
Jump120MPH 01-18-2004, 08:05 AM I got up to 141 mph in 5th..it was time to shift.
Rambling Man 01-18-2004, 09:16 AM Cool thread. On a test drive I had it to 88 in third and barely cracked 6,000 RPM. I've never seen a car harder to redline.
mamccubbin 01-18-2004, 11:08 AM Originally posted by StealthTL
S
No limiter on the US model? I am pretty sure it is limited to 148.
8_wannabe 01-18-2004, 11:12 AM Originally posted by sferrett
Well here's me at the top of 4th gear last weekend - unfortunately the flash reflected off the spedo and I didn't have the presence of mind to look at the preview (ugh - just taking the photo was ridiculous enough). yo, take care out there ferrett. Handling a camera at 130 mph ain't exactly conducive to long life expectancy. We'd like to see you at one of our San Diego gatherings -- in one piece!
btw, what's that black thing sticking up over your dash, at about the 1:00 position on the steering wheel?
FirstSpin 01-18-2004, 01:23 PM Ramblin Man, it's been my experience and I've seen others post it on here, that speed is about 1/100th of rpms in third. That is, at 6,000 rpm's you're apt to be going about 60; at 5,000 - 50 mph etc. I know this is true on my car up to 75 or so. While I've been to the low 90's mph in 3rd I couldn't "testify" about the tach at that speed. I heard no buzzers or bells and wasn't trying to red-line it so my guess is that the relationship gets non-linear at the higher speeds.
Are you sure you were going 88 at 6,000 in 3rd?
sferrett 01-18-2004, 03:19 PM Originally posted by 8_wannabe
I try to limit the number of ridiculous things I do to about one a month - yes I do not recommend repeating my actions and I won't be doing it again myself either (although I am a little bummed about the refelction)
The black thing sticking up is a GPS antenna - I have a mount for my Garmin GPS-V on the dash there so it's easy to see when I'm driving or using it for directions.
eclps0 01-18-2004, 04:28 PM I toped 4th gear at 130-135 and put it in 5th going up to 140 and then i shutdown and just put it in N and coasted to 90 and then rev matched in 6th. I saw my gas needle go down its pretty freeky
joejoe 01-19-2004, 01:00 PM Originally posted by flatso
I did it trying to see if it would save me some gas. You shift about every 2 sec and it did not save me any gas.
Mitch Strickler 01-19-2004, 01:34 PM The calculated max speeds are:
44
79.5
122
By calculated, I mean taking the gearing, in mph/1,000 rpm, and multiplying by the 7,500 rpm redline. This should be accurate for the first three gears, because they should be able to hit redline despite wind (and rolling, etc.) resistance.
Fourth is more interesting. One poster said his AT seemed to cut out at 125, as if Mazda had set it that way. Because the AT is geared at 23.5 mph/1,000 rpm in fourth, the theoretical top is 176. And you might make it with a hurricane tail wind, if you weren't blown off the road or hit with a falling tree first. Based on Mazda figures for the European standard engine, which has a 5 speed manual geared closer to our AT than the MT, I think an ungoverned AT would do about 140. If I get a chance at a long straightaway at Summit Point this Spring, I'll report on how mine performs.
One hint about a Mazda-imposed 125 top would be the rating of the 16" tires that come standard with the AT. The 18" ones for the MT (which I bought in the option package) are rated W: 168 mph. Would someone please give the speed rating for the 16s -- and the wear and heat/traction ratings, too.
Road and Track's calculations are quite close to those reported above, but differ.
They tested a 6-speed Rx-8 and at 9000 RPM, reported the following:
1st-39 mph
2nd-65
3rd-89
4th-124
5th-147
6th-148 at 7650 RPM (electronically limited)
I have found 6th gear to be very close to 20mph per 1000 RPM, so I would reckon the speeds to be slightly higher than Road and Track--more in line with what others calculated above. Speeds over 148 are supposedly not possible, however. I won't be challenging that claim, but has anyone else?
Mitch Strickler 01-19-2004, 05:34 PM Once you get into tiny differences in estimated speeds, it's time to step back and realize that we can't be perfectly precise. The exact diameter of a tire, for example, under different conditions and with different tread wear, or whether the surface is glass-smooth. Sure, 6th in MT is close to 20 mph/1,000. According to Road & Track, 19.4. They doubtless got that with sophisticated instruments, run by experienced testers, and they list the temperature and wind conditions so you can guess at adjusments to your own situation on a given day. For sure, more accurate than comparing a tach and the (optimistic, almost by law) speedometer. My calculator says that R&T's 148 mph is the product of 7,650 rpm -- something that can be checked pretty accurately, I think -- times 19.4. To return to my main point, 148 is a good number, and 146 may be all right, too, or even 150, if it makes someone feel better.
