coolant light comes on when accelerating on the hwy and then goes away???
Old Nov 30, 2009 | 05:06 PM
Vikingdiesel's Avatar
So after the coolant flush and everything, now another issue. When im driving on the highway, the coolant light will come on and stay on for a few minutes and then go away, sometimes when I brake or slow down it goes away too. I check the coolant and its fine. Thoughts?
Old Nov 30, 2009 | 05:08 PM
cjkim's Avatar
^noob
coolant level sensor is going bad
replace or just remember to check it once in awhile.
Old Nov 30, 2009 | 05:11 PM
common problem? Is the coolant sensor a common issue?
Old Nov 30, 2009 | 05:16 PM
cjkim's Avatar
^noob
quite common, mine was starting to go bad also
try adding a bit of distilled water in the overflow tank. might cure it temporarily.
Old Nov 30, 2009 | 05:20 PM
how much for the part? i cant find it on ebay, just coolant temp sensor, also, should the reservoir be filled to the top?
Old Nov 30, 2009 | 05:25 PM
cjkim's Avatar
^noob
http://www.mazmart.com/ItemDetail.aspx?id=531
no, not to the top. there are high and low levels indicated on the side of the overflow tank
Old Nov 30, 2009 | 06:32 PM
Old Rotor's Avatar
If it gets near the low level it will light up. Check it when it is cold in the morn. Add enough to get it near the full mark and if it comes on again then you will need a new tank.
Old Nov 30, 2009 | 07:24 PM
ohh so I pretty much need a whole new reservoir since I cant but the sensor by itself?
Old Nov 30, 2009 | 08:00 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Yep, the whole unit.
Old Nov 30, 2009 | 08:10 PM
rodjonathan's Avatar
silent assasin
surprised noone has said search lol ... i just disconnected mine and monitor the coolant when i check my oil
Old Nov 30, 2009 | 10:20 PM
DarkLord7854's Avatar
Software Engineer
I just overfill mine and that takes care of it.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Azki23
Jun 27, 2018 03:48 PM
ed0128
Sep 9, 2015 04:50 PM
wayloco
Sep 1, 2015 09:03 PM
