weird power loss, intermittent
Old Nov 28, 2009 | 08:27 PM
rx8montreal's Avatar
okay, here is my history! new engine not even 1k! new tranny! new plugs/coils/wire
mazdaspeed CAI/ obx headers/ r1-t exoticspeed 3in cat-back/AP pulleys!
ok here is my problem! its intermittent! on idles = perfect if i push rpm to 9k on neutral everything is fine! now if i push rpm in gears pass 7k it makes a weird noise, like a ratteling coming from the engine( not great at all)+ loss power over 7k through 9k, very bad noise from engine!
runs very good apart that, starts on 1/4 turn even in cold temp! idles great all the time, no grinding noise at all from engine! i checked the headers gasket...
here is my thought! they said at the dealer that my old intake manifold had a problem( clickling noise in the intake) so i went to the scrap ward and got a use intake manifold!
is there possibility that something is obstructing the variable intake system ? cause it sound like when i rev from 7k to 9k something is obstructing somewhere
Old Nov 28, 2009 | 08:28 PM
no cels at all under any conditions
well except for that p0411 cel ( secondary injection pump)
Old Nov 28, 2009 | 08:37 PM
Jon316G's Avatar
Grasshopper
Might want to check the VDI, both the solenoid and the actuator.
Only thing that comes to mind so far.
Did you install the used manifold you got from the scrap yard?
Old Nov 28, 2009 | 08:38 PM
where is this?
Old Nov 28, 2009 | 08:42 PM
Jon316G's Avatar
Grasshopper
The actuator is at the top of the manifold, check it with a vacuum pump and see if it holds vacuum.
The solenoid is almost in front of the oil filter.
When you remove the upper intake manifold you'll see three solenoids stacked on top of each other.
The top is the AIR, the middle is the SSV, and the bottom is the VDI.
Swap the AIR and VDI to see if the sound goes away.
Old Nov 28, 2009 | 08:49 PM
Jon316G's Avatar
Grasshopper
This should help you locate the VDI components:
And watch this to see how to test the actuator:
http://www.vimeo.com/5353829
Old Nov 28, 2009 | 08:55 PM
i have to say that my air is no longer in fuctuin as i have obx headers! i left the secondary air pump unplugged! but that is not the problem!
so i do need to remove the manifold to switch these solenoid?
Old Nov 28, 2009 | 08:59 PM
Jon316G's Avatar
Grasshopper
I've heard that some people can do it without removing the UIM, but I couldn't do it.
And don't bother moving the whole solenoids, just swap the vacuum lines and wire harness between the AIR and VDI solenoid.
Also don't rule out the actuator.
If it has a pinhole, it can't maintain vacuum and the valve can't open completely.
Old Nov 28, 2009 | 09:01 PM
Jon316G's Avatar
Grasshopper
Also you didn't answer my question about the manifold... do you currently have the original that the dealer told you had a problem or are you using the one you bought from the scrap yard?
Old Nov 28, 2009 | 10:21 PM
the one from the scrap yard! the original one .. they kept it and they told me they threw it away!!
Old Nov 28, 2009 | 10:49 PM
Easy_E1's Avatar
Right.
Old Nov 29, 2009 | 12:02 AM
Old Rotor's Avatar
What octane gas are you using...reg or prem? Where do you live?
Old Nov 29, 2009 | 12:04 AM
@!!narotordo's Avatar
FLAME ON!
1. Check all your vac lines are installed right to the intake or capped off.
2. When you installed the AP under drive pulley did you mark the plate thats right behind it? if you intsall the plate wrong=back wards or upside down, your e shafe sencer will throw a cel.
3. Compression test. When I lost my first engine thats what it was doing till I ran it on the freeway and went into limp mode. Could not get past 3k or 4k rpms.
4. Colgged cat?
Old Nov 29, 2009 | 01:09 PM
no cels! pulley was installed by dealer, i use 94 octane from petro-canada! cat is brand new from dealer under 2 k!
Old Nov 29, 2009 | 01:11 PM
i dont know much about this engine! i checked under the hood and all lines seems ok connected
**** i dont know whats wrong! it might be the intake??? but how to trouble shoot it??? i dont know much
Old Nov 29, 2009 | 07:07 PM
FLAME ON!
Have you checked your MAFS? mass air flow sencer?
Old Nov 29, 2009 | 07:28 PM
even with no cel?
Old Nov 29, 2009 | 10:01 PM
FLAME ON!
Yeah the wires get all dryed out and when you remove it to install a CAI you can crack them and not even know it. Cracked wire = short. Checkem it!
Old Nov 29, 2009 | 11:09 PM
i read about the VDI and is it right that this valve opens at 7200rpm?
because my loos of power begins exactly at 7200rpm, feels like there is not enough air coming in, the rpm want to go up but it seems hard to! it feels like no sucking enough air.....
is this a commun problem these solenoid to fail? i will check the MAF wires tomorrow, thanks
Old Nov 29, 2009 | 11:15 PM
Jon316G's Avatar
Grasshopper
7250 RPM if you want to get real technical
The solenoids (AIR, SSV, VDI) have been known to fail.
Sometimes its not the actual solenoid, but the wire harness that connects to them get tarnished from weathering/poor seal.
Sometimes just simply cleaning the contacts in the harness and solenoid have corrected the issue.
Old Dec 2, 2009 | 03:20 PM
maybe its good to say that since i have mazdaspeed CAI, i blocked the hole of the vfad( the vaccum line) with a bolt
Old Dec 2, 2009 | 03:21 PM
still no cel! wow it pisses me off!
Old Dec 2, 2009 | 03:27 PM
Jon316G's Avatar
Grasshopper
Is there a reason you didn't just cap the nipple behind the throttle body?
Its probably better to do this and if you don't have a vacuum cap, Autozone sells a variety pack for a couple bucks.
Old Dec 2, 2009 | 03:33 PM
ok ill do it! but that is not the cause right? i'm pretty sure no but anyway! thanks. i'm going to the dealer monday
Old Dec 2, 2009 | 03:34 PM
they say they can move actuators with the computer in the garage!
