random missfire, loss of power... NEW plugs,wires,and coils... still has problems....
Old Nov 28, 2009 | 07:24 PM
mazdadude8's Avatar
stats: 04 6spd. 110k (org. motor) W/ gutted Cat
New: coils, plugs, wires, battery.
engine codes: p0300 (random missfire)
work done recently:
mazda loss of power recall (done before coils, plugs and wires)
ran the mazda cleaner in the intake system
just finished cleaning the ssv system
cleaned the maf sensor
Car has a rough idle that goes up (1200-500) and down sometimes stalls. No power below 4k, It will bogg out. It will run ok above 4.5 in 1st-3rd gear but has little power 4th-6th at any rpm. Now for the weird thing I unplugged the maf sensor and the car today and it runs alot better almost normal with great power at any rpm, so I am wondering if its a bad maf or something else. I Have taken the car to the dealer to have them work on it but they couldnt figure anything out..... Please help me!!
Old Nov 28, 2009 | 10:11 PM
AJ's Shinka's Avatar
Enthusiast
Can I be the first to say it...new engine! Good news, awesome mileage! Bad news, just out of warranty.
Old Nov 28, 2009 | 10:41 PM
Easy_E1's Avatar
Well it sounds like you fixed the problem. Put a new MAF sensor in there.
Old Nov 28, 2009 | 10:47 PM
@!!narotordo's Avatar
FLAME ON!
It may not be a new engine if the maf is plugged in and causing the issue but when unplugged the car runs fine.
Due to the heat of the engine the wires that connect to the maf may be dryed out stiff and if you remove the mafs to clean it they can brake. Turn the car on and move the wires around. If it runs normal when you move them around and then cuts out back to running like ****. Then its your maf wire harness. Get a new one from the dealer. They are over a C note.
Try to clean the mafs FIRST! try to save you some money first
Old Nov 28, 2009 | 11:11 PM
Jon316G's Avatar
Grasshopper
Do you know any local RX8s that you can temporarily swap MAF sensors with?
Old Nov 28, 2009 | 11:24 PM
FLAME ON!
^Thats what I'm talking about
Old Nov 28, 2009 | 11:27 PM
mazdadude8's Avatar
I do have a buddy im trying to swap with but he isnt answering tonight... Thanks for the help guys I will keep you posted.
Old Nov 28, 2009 | 11:28 PM
Jon316G's Avatar
Grasshopper
Then in the meantime clean your MAF and see if anything changes.
Old Nov 29, 2009 | 01:51 AM
Enthusiast
My bad I thought that he changed the maf. Hope is not lost.
Old Nov 29, 2009 | 02:01 AM
FLAME ON!
All good
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
uZu
Dec 30, 2015 12:35 PM
T_Mags
Sep 3, 2015 11:40 AM
