View Full Version : Vibrations, rough idle when cold
MARIOS KONTEMENIOTIS
11-25-2009, 03:36 AM
Any idea what might be the problem here? I get vibration mostly when cold which fades away as the car is geting warmer. Can feel the vibration right below me. This cause rough idle also which gets better again as the car gets hot. The car is MT. Thanks for your help guys.
Charles R. Hill
11-25-2009, 10:20 AM
Clean your MAF sensor and make sure your air filter is also clean.
ZumnRx8
11-25-2009, 10:21 AM
and chekc ur RAD fluid
tza0001
12-08-2009, 12:01 PM
I was looking at the forum and found all the new and older TSB. One of them is talking about broken engine mounts. Vibrations might be related to broken engine mounts. Take a look, you have nothing to loose.
http://www.finishlineperformance.com....php?pageid=11
12-09-2009, 03:14 AM
Checked the engine mounts, one was broken and replaced, solved the problen, no vibrations, noce idling, thanks a lot
tza0001
12-10-2009, 11:10 AM
Glad you fixed the problem.
